Engineering ToolBox > Abatement and Distance from Source
The disruption of sound pressures waves which reduces the noise is called attenuation
Spherical Distance
sound pressure in distance from source
The sound pressure in a spherical distance from a source can be expressed as:
p2 = ρ c N / (4 π r2) (1)
p = sound pressure (Pa, N/m2)
ρ = density of air (kg/m3)
c = speed of sound (m/s)
N = sound power (W)
π = 3.14
r = distance from source (m)
Half Spherical Distance
The sound pressure in a half spherical distance from a source can be expressed as:
p2 = ρ c N / (4 π r2 / 2) = 2 ρ c N / (4 π r2) (2)
A generic expression can be formulated as:
p2 = D ρ c N / (4 π r2) (3)
D = directivity coefficient
The directivity coefficient depends on several parameters - the position and direction of the source, the room or the surrounding area, etc.
The Sound Pressure Level - Lp - can be expressed as:
Lp = 20 log ( p / pref ) = 20 log ( (D ρ c N / (4 π r2))1/2 / pref )
= 20 log ( 1/r (D ρ c N / (4 π))1/2 / pref ) (4)
pref = 2 10-5 - reference sound pressure (Pa)
Note! For every doubling of the distance from the noise source, the sound pressure levels - Lp, will be reduced by 6 decibels.
