Engineering ToolBox > Calculate Decibel
The logarithmic decibel scale is convenient when calculating resulting sound power levels and sound pressure levels for two or more sound or noise sources.
Adding Equal Sound Power Sources
The resulting sound power when adding equal sound power sources can be expressed as:
Lwt =  10 log(n N / No)
    = 10 log(N / No) + 10 log(n)
    = Lws + 10 log(n)         (1)
Lwt = the total sound power level (dB
Lws= sound power level from each single source (dB)
N = sound power (W)
No = 10-12 - reference sound power (W)
n = number of sources
The adding of equal sound power sources can also be expressed graphically as
adding equal sound level sources
Note! Adding two identical sources will increase the total sound power level with 3 dB ( 10 log(2) ).
The sound power and sound power level is commonly used to specify the emitted noise or sound from technical equipment as fans, pump and other machines. The sound measured with microphones is the sound pressure
Adding Equal Sound Pressure Levels
The resulting sound pressure level when adding equal sound pressure can be expressed as:
Lpt = Lps + 20 log(n)      (2)
Lpt = total sound pressure level (dB)
Lps = sound pressure level from each single source (dB)
Number of Sources Increase in Sound Power Level
(dB)
Increase in Sound Pressure Level
(dB)
2 3 6
3 4.8 9.6
4 6 12
5 7 14
10 10 20
15 11.8 23.6
20 13 26
Adding Sound Power from Sources at different Levels
The sound power level from more than one source can be calculated as:
Lwt =  10 log( (N1 + N2 ... + Nn) / No)    (3)
Adding two sources at different levels can be expressed graphically as
adding different sound levels diagram
Sound Power Level Difference between
two Sound Sources
(dB)
Added Decibel to the Highest Sound Power Level
(dB)
0 3
1 2.5
2 2
3 2
4 1.5
5 1
6 1
7 1
8 0.5
9 0.5
10 0.5
> 10 0
