Engineering ToolBox > Air - Altitude, Density and Specific Volume
The density and the specific volume of air varies with the elevation above sea level
The density of air will vary with the pressure (the Ideal Gas Law) and the altitude above sea level. Mean absolute pressure at sea level is approximately 760 mmHg (101.325 kPa, kN/m2) with a variation is about +/- 5%.
Altitude and Air Pressure
The air pressure varies with altitude as shown in the table below:
Altitude
(m)
Barometer
(mmHg)
0 760
75 753
150 746
250 739
300 733
450 719
600 706
750 693
900 681
1,000 668
1,200 656
1,350 644
1,500 632
1,800 609
2,100 586
2,400 564
Altitude and Air Density
Air density and specific volume as functions of altitude above sea level are indicated in the diagrams below:
air altitude meters density and specific volume diagram
air altitude feet density and specific volume diagram
STP - Standard Temperature and Pressure
NTP - Normal Temperature and Pressure
Altitude and Specific Volume Correction
The specific volume of standard air at a certain altitude can be calculated by multiplying with the volume correction factor below
Altitude Volume Correction Factor
(m) (ft)
0 0 1.00
480 1600 1.05
990 3300 1.11
1500 5000 1.17
1980 6600 1.24
2460 8200 1.31
2970 9900 1.39
