AISI/SAE Steel - Numbering System
Steel numbering system
AISI/SAE steel numbers are indicated below.
Example AISI/SAE No. 1020
  • the first digit indicates that this is plain carbon steel.
  • the second digit indicates there are no alloying elements
  • the last two digits indicates that the steel contains approximately 0.20 percent carbon
Example AISI/SAE No. 4340
  • the first two digits indicates a Nickel-Chromium-Molybdenum alloy steel
  • the last two digits indicates carbon content roughly 0.4 percent
10XX Carbon steels Plain carbon, Mn 1.00% max
11XX Resulfurized free machining
12XX Resulfurized / rephosphorized free machining
15XX Plain carbon, Mn 1.00-1.65%
13XX Manganese steel Mn 1.75%
23XX Nickel steels Ni 3.50%
25XX Ni 5.00%
31XX Nickel-chromium steels Ni 1.25%, Cr 0.65-0.80%
32XX Ni 1.75%, Cr 1.07%
33XX Ni 3.50%, Cr 1.50-1.57%
34XX Ni 3.00%, Cr 0.77%
40XX Molybdenum steels Mo 0.20-0.25%
44XX Mo 0.40-0.52%
41XX Chromium-molybdenum steels Cr 0.50-0.95%, Mo 0.12-0.30%
43XX Nickel-chromium-molybdenum steels Ni 1.82%, Cr 0.50-0.80%, Mo 0.25%
47XX Ni 1.05%, Cr 0.45%, Mo 0.20-0.35%
46XX Nickel-molybdenum steels Ni 0.85-1.82%, Mo 0.20-0.25%
48XX Ni 3.50%, Mo 0.25%
50XX Chromium steels Cr 0.27-0.65%
51XX Cr 0.80-1.05%
50XXX Cr 0.50%, C 1.00% min
51XXX Cr 1.02%, C 1.00% min
52XXX Cr 1.45%, C 1.00% min
61XX Chromium-vanadium steels Cr 0.60-0.95%, V 0.10-0.15%
72XX Tungsten-chromium steels W 1.75%, Cr 0.75%
81XX Nickel-chromium-molybdenum steels Ni .30%, Cr 0.40%, Mo 0.12%
86XX Ni .55%, Cr 0.50%, Mo 0.20%
87XX Ni .55%, Cr 0.50%, Mo 0.25%
88XX Ni .55%, Cr 0.50%, Mo 0.35%
92XX Silicon-manganese steels Si 1.40-2.00%, Mn 0.65-0.85%, Cr 0-0.65%
93XX Nickel-chromium-molybdenum steels Ni 3.25%, Cr 1.20%, Mo 0.12%
94XX Ni 0.45%, Cr 0.40%, Mo 0.12%
97XX Ni 0.55%, Cr 0.20%, Mo 0.20%
98XX Ni 1.00%, Cr 0.80%, Mo 0.25%
Search the Engineering Toolbox
  • Material Properties - Material properties - density, heat capacity, viscosity and more - for gases, fluids and solids
ToolBox Tools
3D Engineering ToolBox - draw and model technical applications! 3D Engineering ToolBox - 3D modelling of technical applications with Google SketchUp!
2D Engineering ToolBox - create and share online diagram drawing templates! 2D Engineering ToolBox - create and share online diagram drawings with Google Docs!
Engineering ToolBox Apps - mobile online and offline engineering applications! Engineering ToolBox Apps - mobile online and offline engineering applications!
Disclaimers
The content in The Engineering ToolBox is COPYRIGHTED but can be used with NO WARRANTY or LIABILITY
Important information should always be double checked with alternative sources. All applicable national and local regulations and practices concerning this aspects must be strictly followed and adhered to. Contact Us!
Desktop Edition!
