Engineering ToolBox > American Standard Steel Channels
Dimensions and static parameters of American Standard Steel Channels
american standard steel channel
Properties  in imperial units of American Steel Channels are indicated below.
Designation Dimensions Static Parameters
Moment of Inertia Section Modulus
Imperial
(in x lb/ft)
Depth
h
(in)
With
w
(in)
Web Thickness
s
(in)
Sectional Area
(in2)
Weight
(lb/ft)
Ix
(in4)
Iy
(in4)
Wx
(in3)
Wy
(in3)
C 15 x 50 15 3.716 0.716 14.7 50 404 11.0 53.8 3.78
C 15 x 40 15 3.520 0.520 11.8 40 349 9.23 46.5 3.37
C 15 x 33.9 15 3.400 0.400 9.96 33.9 315 8.13 42.0 3.11
C 12 x 30 12 3.170 0.510 8.82 30 162 5.14 27.0 2.06
C 12 x 25 12 3.047 0.387 7.35 25 144 4.47 24.1 1.88
C 12 x 20.7 12 2.942 0.282 6.09 20.7 129 3.88 21.5 1.73
C 10 x 30 10 3.033 0.673 8.82 30 103 3.94 20.7 1.65
C 10 x 25 10 2.886 0.526 7.35 25 91.2 3.36 18.2 1.48
C 10 x 20 10 2.739 0.379 5.88 20 78.9 2.81 15.8 1.32
C 10 x 15.3 10 2.600 0.240 4.49 15.3 67.4 2.28 13.5 1.16
C 9 x 20 9 2.648 0.448 5.88 20 60.9 2.42 13.5 1.17
C 9 x 15 9 2.485 0.285 4.41 15 51.0 1.93 11.3 1.01
C 9 x 13.4 9 2.433 0.233 3.94 13.4 47.9 1.76 10.6 0.96
C 8 x 18.75 8 2.527 0.487 5.51 18.75 44.0 1.98 11.0 1.01
C 8 x 13.75 8 2.343 0.303 4.04 13.75 36.1 1.53 9.03 0.85
C 8 x 11.75 8 2.260 0.220 3.38 11.5 32.6 1.32 8.14 0.78
C 7 x 14.75 7 2.299 0.419 4.33 14.75 27.2 1.38 7.78 0.78
C 7 x 12.25 7 2.194 0.314 3.60 12.25 24.2 1.17 6.93 0.70
C 7 x 9.8 7 2.090 0.210 2.87 9.8 21.3 0.97 6.08 0.63
C 6 x 13 6 2.157 0.437 3.83 13 17.4 1.05 5.80 0.64
C 6 x 10.5 6 2.034 0.314 3.09 10.5 15.2 0.87 5.06 0.56
C 6 x 8.2 6 1.920 0.200 2.40 8.2 13.1 0.69 4.38 0.49
C 5 x 9 5 1.885 0.325 2.64 9 8.90 0.63 3.56 0.45
C 5 x 6.7 5 1.750 0.190 1.97 6.7 7.49 0.48 3.00 0.38
C 4 x 7.25 4 1.721 0.321 2.13 7.25 4.59 0.43 2.29 0.34
C 4 x 5.4 4 1.584 0.184 1.59 5.4 3.85 0.32 1.93 0.28
C 3 x 6 3 1.596 0.356 1.76 6 2.07 0.31 1.38 0.27
C 3 x 5 3 1.498 0.258 1.47 5 1.85 0.25 1.24 0.23
C 3 x 4.1 3 1.410 0.170 1.21 4.1 1.66 0.20 1.10 0.20
The standard method for specifying the dimensions of a American Standard Steel Channels is like C 5 x 9. which is a beam 5 inches deep with a weight 9 lb/ft.
I-shaped cross-section beams:
