Engineering ToolBox > American Wide Flange Beams
Properties of American Wide Flange Beams according ASTM A6 in metric units are indicated below.
| Designation | Dimensions | Static Parameters | ||||||||
| Moment of Inertia | Section Modulus | |||||||||
| Imperal (in x in x lb/ft) | Metric (mm x mm x kg/m) | Depth h (mm) | Width w (mm) | Web Thickness s (mm) | Sectional Area (cm2) | Weight (kg/m) | Ix (cm4) | Iy (cm4) | Wx (cm3) | Wy (cm3) |
| W 4 x 4 x 13 | W 100 x 100 x 19.3 | 106 | 103 | 7.1 | 24.7 | 19.3 | 475.9 | 160.6 | 89.9 | 31.2 |
| W 5 x 5 x 16 | W 130 x 130 x 23.8 | 127 | 127 | 6.1 | 30.4 | 23.8 | 885.5 | 311 | 139.5 | 49 |
| W 5 x 5 x 19 | W 130 x 130 x 28.1 | 131 | 128 | 6.9 | 35.9 | 28.1 | 1099 | 381.4 | 167.7 | 59.6 |
| W 6 x 4 x 9 | W 150 x 100 x 13.5 | 150 | 100 | 4.3 | 17.3 | 13.5 | 685.5 | 91.8 | 91.4 | 18.4 |
| W 6 x 4 x 12 | W 150 x 100 x 18.0 | 153 | 102 | 5.8 | 22.9 | 18 | 915.9 | 125.9 | 122.1 | 25.4 |
| W 6 x 4 x 16 | W 150 x 100 x 24.0 | 160 | 102 | 6.6 | 30.6 | 24 | 1342 | 182.6 | 167.8 | 35.8 |
| W 6 x 6 x 15 | W 150 x 150 x 22.5 | 152 | 152 | 5.8 | 28.6 | 22.5 | 1206 | 386.6 | 158.6 | 50.9 |
| W 6 x 6 x 20 | W 150 x 150 x 29.8 | 157 | 153 | 6.6 | 37.9 | 29.8 | 1714 | 555.5 | 218.4 | 72.6 |
| W 6 x 6 x 25 | W 150 x 150 x 37.1 | 162 | 154 | 8.1 | 47.4 | 37.1 | 2220 | 706.8 | 274.1 | 91.8 |
| W 8 x 4 x 10 | W 200 x 100 x 15.0 | 200 | 100 | 4.3 | 19.1 | 15 | 1280 | 86.9 | 128 | 17.4 |
| W 8 x 4 x 13 | W 200 x 100 x 19.3 | 203 | 102 | 5.8 | 24.8 | 19.3 | 1662 | 115.4 | 163.7 | 22.6 |
| W 8 x 4 x 15 | W 200 x 100 x 22.5 | 206 | 102 | 6.2 | 28.6 | 22.5 | 2004 | 142 | 194.5 | 27.8 |
| W 8 x 5.25 x 18 | W 200 x 135 x 26.6 | 207 | 133 | 5.8 | 33.9 | 26.6 | 2587 | 329.8 | 250 | 49.6 |
| W 8 x 5.25 x 21 | W 200 x 135 x 31.3 | 210 | 134 | 6.4 | 39.7 | 31.3 | 3139 | 409.6 | 290 | 61.1 |
| W 8 x 6.5 x 24 | W 200 x 165 x 35.9 | 201 | 165 | 6.2 | 45.7 | 35.9 | 3438 | 764.3 | 342.1 | 92.6 |
| W 8 x 6.5 x 28 | W 200 x 165 x 41.7 | 205 | 166 | 7.2 | 53.2 | 41.7 | 4088 | 900.5 | 399 | 108.5 |
| W 8 x 8 x 31 | W 200 x 200 x 46.1 | 203 | 203 | 7.2 | 58.9 | 46.1 | 4545 | 1535 | 448 | 151.2 |
| W 8 x 8 x 35 | W 200 x 200 x 52 | 206 | 204 | 7.9 | 66.5 | 52 | 5268 | 1784 | 512 | 174.9 |
| W 8 x 8 x 40 | W 200 x 200 x 59 | 210 | 205 | 9.1 | 75.5 | 59 | 6113 | 2040 | 582 | 199.1 |
| W 8 x 8 x 48 | W 200 x 200 x 71 | 216 | 206 | 10.2 | 91 | 71 | 7658 | 2537 | 709 | 246.3 |
| W 8 x 8 x 58 | W 200 x 200 x 86 | 222 | 209 | 13 | 110 | 86 | 9467 | 3138 | 853 | 300.3 |
| W 8 x 8 x 67 | W 200 x 200 x 100 | 229 | 210 | 14.5 | 127 | 100 | 11325 | 3663 | 989 | 348.9 |
| W 10 x 4 x 12 | W 250 x 100 x 17.9 | 251 | 101 | 4.8 | 22.8 | 17.9 | 2254 | 91.3 | 179.5 | 18.1 |
| W 10 x 4 x 15 | W 250 x 100 x 22.3 | 254 | 102 | 5.8 | 28.5 | 22.3 | 2901 | 122.6 | 228.4 | 24 |
| W 10 x 4 x 17 | W 250 x 100 x 25.3 | 257 | 102 | 6.1 | 32.2 | 25.3 | 3430 | 149.2 | 266.9 | 29.3 |
| W 10 x 4 x 19 | W 250 x 100 x 28.4 | 260 | 102 | 6.4 | 36.3 | 28.4 | 3998 | 177.5 | 307.5 | 34.8 |
| W 10 x 5.75 x 22 | W 250 x 145 x 32.7 | 258 | 146 | 6.1 | 41.9 | 32.7 | 4895 | 472.6 | 379.4 | 64.7 |
| W 10 x 5.75 x 26 | W 250 x 145 x 38.5 | 262 | 147 | 6.6 | 49.1 | 38.5 | 6014 | 593.7 | 459.1 | 80.8 |
| W 10 x 5.75 x 30 | W 250 x 145 x 44.8 | 266 | 148 | 7.6 | 57 | 44.8 | 7118 | 703.5 | 535.2 | 95.1 |
| W 10 x 8 x 33 | W 250 x 200 x 49.1 | 247 | 202 | 7.4 | 62.6 | 49.1 | 7069 | 1513 | 572.4 | 149.8 |
| W 10 x 8 x 39 | W 250 x 200 x 58 | 252 | 203 | 8 | 74.2 | 58 | 8736 | 1884 | 693.4 | 185.6 |
| W 10 x 8 x 45 | W 250 x 200 x 67 | 257 | 204 | 8.9 | 85.8 | 67 | 10360 | 2224 | 806.6 | 218 |
| W 10 x 10 x 49 | W 250 x 250 x 73 | 253 | 254 | 8.6 | 92.9 | 73 | 11290 | 3880 | 892.1 | 305.5 |
| W 10 x 10 x 54 | W 250 x 250 x 80 | 256 | 255 | 9.4 | 102 | 80 | 12570 | 4314 | 982.4 | 338.3 |
| W 10 x 10 x 60 | W 250 x 250 x 89 | 260 | 256 | 10.7 | 114 | 89 | 14260 | 4841 | 1097 | 378.2 |
| W 10 x 10 x 68 | W 250 x 250 x 101 | 264 | 257 | 11.9 | 129 | 101 | 16380 | 5549 | 1241 | 431.9 |
| W 10 x 10 x 77 | W 250 x 250 x 115 | 269 | 259 | 13.5 | 146 | 115 | 18940 | 6405 | 1408 | 494.6 |
| W 10 x 10 x 88 | W 250 x 250 x 131 | 275 | 261 | 15.4 | 167 | 131 | 22150 | 7446 | 1611 | 570.6 |
| W 10 x 10 x 100 | W 250 x 250 x 149 | 282 | 263 | 17.3 | 190 | 149 | 25940 | 8622 | 1840 | 655.7 |
| W 10 x 10 x 112 | W 250 x 250 x 167 | 289 | 265 | 19.2 | 212 | 167 | 30020 | 9879 | 2078 | 745.6 |
| W 12 x 4 x 14 | W 310 x 100 x 21 | 303 | 101 | 5.1 | 26.8 | 21 | 3708 | 98.3 | 244.8 | 19.5 |
| W 12 x 4 x 16 | W 310 x 100 x 23.8 | 305 | 101 | 5.6 | 30.4 | 23.8 | 4280 | 115.6 | 280.7 | 22.9 |
| W 12 x 4 x 19 | W 310 x 100 x 28.3 | 309 | 102 | 6 | 35.9 | 28.3 | 5431 | 158.1 | 351.5 | 31 |
| W 12 x 4 x 22 | W 310 x 100 x 32.7 | 313 | 102 | 6.6 | 41.8 | 32.7 | 6507 | 191.9 | 415.8 | 37.6 |
| W 12 x 6.5 x 26 | W 310 x 165 x 38.7 | 310 | 165 | 5.8 | 49.4 | 38.7 | 8527 | 726.8 | 550.1 | 88.1 |
| W 12 x 6.5 x 30 | W 310 x 165 x 44.5 | 313 | 166 | 6.6 | 56.7 | 44.5 | 9934 | 854.7 | 634.8 | 103 |
| W 12 x 6.5 x 35 | W 310 x 165 x 52 | 317 | 167 | 7.6 | 66.5 | 52 | 11851 | 1026 | 747.7 | 122.9 |
| W 12 x 8 x 40 | W 310 x 200 x 60 | 303 | 203 | 7.5 | 76.1 | 60 | 12860 | 1829 | 849 | 180.8 |
| W 12 x 8 x 45 | W 310 x 200 x 67 | 306 | 204 | 8.5 | 85.2 | 67 | 14510 | 2069 | 984 | 202.8 |
| W 12 x 8 x 50 | W 310 x 200 x 74 | 310 | 205 | 9.4 | 94.8 | 74 | 16450 | 2344 | 1061 | 228.7 |
| W 12 x 10 x 53 | W 310 x 250 x 79 | 306 | 254 | 8.8 | 101 | 79 | 17670 | 3990 | 1155 | 314.2 |
| W 12 x 10 x 58 | W 310 x 250 x 86 | 310 | 254 | 9.1 | 110 | 86 | 19850 | 4455 | 1280 | 350.8 |
| W 12 x 12 x 65 | W 310 x 310 x 97 | 308 | 305 | 9.9 | 123 | 97 | 22240 | 7286 | 1444 | 477.8 |
| W 12 x 12 x 72 | W 310 x 310 x 107 | 311 | 306 | 10.9 | 136 | 107 | 24790 | 8123 | 1594 | 530.9 |
| W 12 x 12 x 79 | W 310 x 310 x 117 | 314 | 307 | 11.9 | 150 | 117 | 27510 | 9024 | 1753 | 587.9 |
| W 12 x 12 x 87 | W 310 x 310 x 129 | 318 | 308 | 13.1 | 165 | 129 | 30770 | 10040 | 1935 | 651.9 |
| W 12 x 12 x 96 | W 310 x 310 x 143 | 323 | 309 | 14 | 182 | 143 | 34760 | 11270 | 2153 | 729.4 |
| W 12 x 12 x 106 | W 310 x 310 x 158 | 327 | 310 | 15.5 | 201 | 158 | 38630 | 12470 | 2363 | 804.8 |
| W 12 x 12 x 120 | W 310 x 310 x 179 | 333 | 313 | 18 | 228 | 179 | 44530 | 14380 | 2675 | 918.7 |
| W 12 x 12 x 136 | W 310 x 310 x 202 | 341 | 315 | 20.1 | 257 | 202 | 51982 | 16588 | 3049 | 1053 |
| W 12 x 12 x 152 | W 310 x 310 x 226 | 348 | 317 | 22.1 | 288 | 226 | 59560 | 18930 | 3423 | 1194 |
| W 12 x 12 x 170 | W 310 x 310 x 253 | 356 | 319 | 24.4 | 323 | 253 | 68230 | 21460 | 3833 | 1346 |
| W 12 x 12 x 190 | W 310 x 310 x 283 | 365 | 322 | 26.9 | 360 | 283 | 78680 | 24590 | 4311 | 1527 |
| W 12 x 12 x 210 | W 310 x 310 x 313 | 374 | 325 | 30 | 399 | 313 | 89560 | 27700 | 4789 | 1705 |
| W 12 x 12 x 230 | W 310 x 310 x 342 | 382 | 328 | 32.6 | 437 | 342 | 100510 | 31020 | 5262 | 1892 |
The standard method for specifying the dimensions of a American Wide Flange Beam is for example W 310 x 250 x 79, which is 310 mm deep, 250 mm wide and with a weight of 79 kg/m.
I-shaped cross-section beams:
