Argon
Chemical, Physical and Thermal Properties of Argon
Chemical, physical and thermal properties of Argon  - Ar :
Molecular Weight 39.948
Specific Gravity 1.38
Specific Volume (ft3/lb, m3/kg) 9.8, 0.622
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 87.0, 1400
Absolute Viscosity (lbm/ft s, centipoises) 13.4 10-6, 0.02
Sound velocity in gas (m/s) 322
Specific Heat - cp - (Btu/lboF or cal/goC, J/kgK) 0.125, 523
Specific Heat Ratio - cp/cv 1.67
Gas constant - R - (ft lb/lboR, J/kgoC) 38.7, 208
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.0102, 0.0172
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) -303, -186
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 70, 163000
Freezing or Melting Point  at 1 atm (oF, oC) -308.5, -189.2
Critical Temperature (oF, oC) -187.6, -122
Critical Pressure (psia, MN/m2) 707, 4.87
Critical Volume (ft3/lb, m3/kg) 0.0299, 0.00186
Flammable no
Search the Engineering Toolbox
  • Material Properties - Material properties - density, heat capacity, viscosity and more - for gases, fluids and solids
ToolBox Tools
3D Engineering ToolBox - draw and model technical applications! 3D Engineering ToolBox - 3D modelling of technical applications with Google SketchUp!
2D Engineering ToolBox - create and share online diagram drawing templates! 2D Engineering ToolBox - create and share online diagram drawings with Google Docs!
Engineering ToolBox Apps - mobile online and offline engineering applications! Engineering ToolBox Apps - mobile online and offline engineering applications!
Disclaimers
The content in The Engineering ToolBox is COPYRIGHTED but can be used with NO WARRANTY or LIABILITY
Important information should always be double checked with alternative sources. All applicable national and local regulations and practices concerning this aspects must be strictly followed and adhered to. Contact Us!
Desktop Edition!
