Engineering ToolBox > Carbon, Alloy and Stainless Steel Pipes - ASME/ANSI B36.10/19
Covers the standardization of dimensions of welded and seamless wrought steel pipe for high and low temperatures and pressures.
The steel pipe data chart below can be used to find pipe sizes, diameters, wall thickness, working pressures and more The chart is based on ASME/ANSI B 36.10 Welded and Seamless Wrought Steel Pipe and ASME/ANSI B36.19 Stainless Steel Pipe.
Regardless of schedule number, pipes of a particular size all have the same outside diameter (not withstanding manufacturing tolerances). As the schedule number increases, the wall thickness increases, and the actual bore is reduced. For example:
| Diameter Nominal | Schedule | Outside Diameter - D - (mm) | Wall Thickness - t - (mm) | Inside Diameter - d - (mm) | Inside Area (cm2) | Pipe Weight (kg/m) | Water Weight (kg/m) | ||
| (inches) | (mm) | ||||||||
| 1/8 | 3 | 10S | 10.3 | 1.245 | 7.811 | 0.479 | 0.277 | 0.048 | |
| Std | 40 | 1.727 | 6.846 | 0.368 | 0.364 | 0.037 | |||
| XS | 80 | 2.413 | 5.474 | 0.235 | 0.468 | 0.024 | |||
| 1/4 | 6 | 10S | 13.7 | 1.651 | 10.398 | 0.846 | 0.489 | 0.085 | |
| Std | 40 | 2.235 | 9.23 | 0.669 | 0.630 | 0.067 | |||
| XS | 80 | 3.023 | 7.654 | 0.460 | 0.794 | 0.046 | |||
| 3/8 | 10 | 10S | 17.145 | 1.651 | 13.843 | 1.505 | 0.629 | 0.151 | |
| Std | 40 | 2.311 | 12.523 | 1.232 | 0.843 | 0.123 | |||
| XS | 80 | 3.2 | 10.745 | 0.907 | 1.098 | 0.091 | |||
| 1/2 | 15 | 5S | 21.336 | 1.651 | 18.034 | 2.554 | 0.799 | 0.255 | |
| 10S | 2.108 | 17.12 | 2.302 | 0.997 | 0.230 | ||||
| Std | 40 | 2.769 | 15.798 | 1.960 | 1.265 | 0.190 | |||
| XS | 80 | 3.734 | 13.868 | 1.510 | 1.617 | 0.151 | |||
| 160 | 4.75 | 11.836 | 1.100 | 1.938 | 0.110 | ||||
| XXS | 7.468 | 6.4 | 0.322 | 2.247 | 0.032 | ||||
| 3/4 | 20 | 5S | 26.67 | 1.651 | 23.368 | 4.289 | 1.016 | 0.429 | |
| 10S | 2.108 | 22.454 | 3.960 | 1.273 | 0.396 | ||||
| Std | 40 | 2.87 | 20.93 | 3.441 | 1.680 | 0.344 | |||
| XS | 80 | 3.912 | 18.846 | 2.790 | 2.190 | 0.279 | |||
| 160 | 5.537 | 15.596 | 1.910 | 2.878 | 0.191 | ||||
| XXS | 7.823 | 11.024 | 0.954 | 3.626 | 0.095 | ||||
| 1 | 25 | 5S | 33.401 | 1.651 | 30.099 | 7.115 | 1.289 | 0.712 | |
| 10S | 2.769 | 27.863 | 6.097 | 2.086 | 0.610 | ||||
| Std | 40 | 3.378 | 26.645 | 5.576 | 2.494 | 0.558 | |||
| XS | 80 | 4.547 | 24.307 | 4.640 | 3.227 | 0.464 | |||
| 160 | 6.35 | 20.701 | 3.366 | 4.225 | 0.337 | ||||
| XXS | 9.093 | 15.215 | 1.818 | 5.436 | 0.182 | ||||
| 1 1/4 | 32 | 5S | 42.164 | 1.651 | 38.862 | 11.862 | 1.645 | 1.186 | |
| 10S | 2.769 | 36.626 | 10.536 | 2.683 | 1.054 | ||||
| Std | 40 | 3.556 | 35.052 | 9.650 | 3.377 | 0.965 | |||
| XS | 80 | 4.851 | 32.462 | 8.276 | 4.452 | 0.828 | |||
| 160 | 6.35 | 29.464 | 6.818 | 5.594 | 0.682 | ||||
| XXS | 9.703 | 22.758 | 4.068 | 7.747 | 0.407 | ||||
| 1 1/2 | 40 | 5S | 48.26 | 1.651 | 44.958 | 15.875 | 1.893 | 1.587 | |
| 10S | 2.769 | 42.722 | 14.335 | 3.098 | 1.433 | ||||
| Std | 40 | 3.683 | 40.894 | 13.134 | 4.038 | 1.313 | |||
| XS | 80 | 5.08 | 38.1 | 11.401 | 5.395 | 1.140 | |||
| 160 | 7.137 | 33.986 | 9.072 | 7.219 | 0.907 | ||||
| XXS | 10.16 | 27.94 | 6.131 | 9.521 | 0.613 | ||||
| 13.335 | 21.59 | 3.661 | 11.455 | 0.366 | |||||
| 15.875 | 16.51 | 2.141 | 12.645 | 0.214 | |||||
| 2 | 50 | 5S | 60.325 | 1.651 | 57.023 | 25.538 | 2.383 | 2.554 | |
| 10S | 2.769 | 54.787 | 23.575 | 3.920 | 2.357 | ||||
| Std | 40 | 3.912 | 52.501 | 21.648 | 5.428 | 2.165 | |||
| XS | 80 | 5.537 | 49.251 | 19.051 | 7.461 | 1.905 | |||
| 160 | 8.712 | 42.901 | 14.455 | 11.059 | 1.446 | ||||
| XXS | 11.074 | 38.177 | 11.447 | 13.415 | 1.145 | ||||
| 14.275 | 31.775 | 7.930 | 16.168 | 0.793 | |||||
| 17.45 | 25.425 | 5.077 | 18.402 | 0.508 | |||||
| 2 1/2 | 65 | 5S | 73.025 | 2.108 | 68.809 | 37.186 | 3.677 | 3.719 | |
| 10S | 3.048 | 66.929 | 35.182 | 5.246 | 3.518 | ||||
| Std | 40 | 5.156 | 62.713 | 30.889 | 8.607 | 3.089 | |||
| XS | 80 | 7.01 | 59.005 | 27.344 | 11.382 | 2.734 | |||
| 160 | 9.525 | 53.975 | 22.881 | 14.876 | 2.288 | ||||
| XXS | 14.021 | 44.983 | 15.892 | 20.348 | 1.589 | ||||
| 17.145 | 38.735 | 11.784 | 23.564 | 1.178 | |||||
| 20.32 | 32.385 | 8.237 | 26.341 | 0.824 | |||||
| 3 | 80 | 5S | 88.9 | 2.108 | 84.684 | 56.324 | 4.5 | 5.632 | |
| 10S | 3.048 | 82.804 | 53.851 | 6.436 | 5.385 | ||||
| Std | 40 | 5.486 | 77.928 | 47.696 | 11.255 | 4.770 | |||
| XS | 80 | 7.62 | 73.66 | 42.614 | 15.233 | 4.261 | |||
| 160 | 11.1 | 66.7 | 34.942 | 21.240 | 3.494 | ||||
| XXS | 15.24 | 58.42 | 26.805 | 27.610 | 2.680 | ||||
| 18.415 | 52.07 | 21.294 | 31.925 | 2.129 | |||||
| 21.59 | 45.72 | 16.417 | 35.743 | 1.642 | |||||
| 3 1/2 | 90 | 5S | 101.6 | 2.108 | 97.384 | 74.485 | 5.158 | 7.448 | |
| 10S | 40 | 3.048 | 95.504 | 71.636 | 7.388 | 7.164 | |||
| Std | 80 | 5.74 | 90.12 | 63.787 | 13.533 | 6.379 | |||
| XS | 8.077 | 85.446 | 57.342 | 18.579 | 5.734 | ||||
| XXS | 16.154 | 69.292 | 37.710 | 33.949 | 3.771 | ||||
| 4 | 100 | 5S | 114.3 | 2.108 | 110.084 | 95.179 | 5.817 | 9.518 | |
| 10S | 3.048 | 108.204 | 91.955 | 8.340 | 9.196 | ||||
| 4.775 | 104.75 | 86.179 | 12.863 | 8.618 | |||||
| Std | 40 | 6.02 | 102.26 | 82.130 | 16.033 | 8.213 | |||
| XS | 80 | 8.56 | 97.18 | 74.173 | 22.262 | 7.417 | |||
| 120 | 11.1 | 92.1 | 66.621 | 28.175 | 6.662 | ||||
| 12.7 | 88.9 | 62.072 | 31.736 | 6.207 | |||||
| 160 | 13.487 | 87.326 | 59.893 | 33.442 | 5.989 | ||||
| XXS | 17.12 | 80.06 | 50.341 | 40.920 | 5.034 | ||||
| 20.32 | 73.66 | 42.614 | 46.970 | 4.261 | |||||
| 23.495 | 67.31 | 35.584 | 52.474 | 3.558 | |||||
| 5 | 125 | 5S | 141.3 | 2.769 | 135.762 | 144.76 | 9.435 | 14.476 | |
| 10S | 3.404 | 134.492 | 142.06 | 11.545 | 14.206 | ||||
| Std | 40 | 6.553 | 128.194 | 129.07 | 21.718 | 12.907 | |||
| XS | 80 | 9.525 | 122.25 | 117.38 | 30.871 | 11.738 | |||
| 120 | 12.7 | 115.9 | 105.50 | 40.170 | 10.550 | ||||
| 160 | 15.875 | 109.55 | 94.254 | 48.973 | 9.426 | ||||
| XXS | 19.05 | 103.2 | 83.647 | 57.280 | 8.365 | ||||
| 22.225 | 96.85 | 73.670 | 65.091 | 7.367 | |||||
| 25.4 | 90.5 | 64.326 | 72.406 | 6.433 | |||||
| 6 | 150 | 5S | 168.275 | 2.769 | 162.737 | 208.00 | 11.272 | 20.800 | |
| 10S | 3.404 | 161.467 | 204.77 | 13.804 | 20.477 | ||||
| 5.563 | 157.149 | 193.96 | 22.263 | 19.396 | |||||
| Std | 40 | 7.112 | 154.051 | 186.39 | 28.191 | 18.639 | |||
| XS | 80 | 10.973 | 146.329 | 168.17 | 42.454 | 16.817 | |||
| 120 | 14.275 | 139.725 | 153.33 | 54.070 | 15.333 | ||||
| 160 | 18.237 | 131.801 | 136.44 | 67.300 | 13.644 | ||||
| XXS | 21.946 | 124.383 | 121.51 | 78.985 | 12.151 | ||||
| 25.4 | 117.475 | 108.39 | 89.258 | 10.839 | |||||
| 28.575 | 111.125 | 96.987 | 98.184 | 9.699 | |||||
| 8 | 200 | 5S | 219.075 | 2.769 | 213.537 | 358.13 | 14.732 | 35.813 | |
| 10S | 3.759 | 211.557 | 351.52 | 19.907 | 35.152 | ||||
| 5.563 | 207.949 | 339.63 | 29.217 | 33.963 | |||||
| 20 | 6.35 | 206.375 | 334.51 | 33.224 | 33.451 | ||||
| 30 | 7.036 | 205.003 | 330.07 | 36.694 | 33.007 | ||||
| Std | 40 | 8.179 | 202.717 | 322.75 | 42.425 | 32.275 | |||
| 60 | 10.312 | 198.451 | 309.31 | 52.949 | 30.931 | ||||
| XS | 80 | 12.7 | 193.675 | 294.60 | 64.464 | 29.460 | |||
| 100 | 15.062 | 188.951 | 280.41 | 75.578 | 28.041 | ||||
| 120 | 18.237 | 182.601 | 261.88 | 90.086 | 26.188 | ||||
| 140 | 20.625 | 177.825 | 248.36 | 100.671 | 24.836 | ||||
| 160 | 23.012 | 173.051 | 235.20 | 110.970 | 23.520 | ||||
| 25.4 | 168.275 | 222.40 | 120.994 | 22.240 | |||||
| 28.575 | 161.925 | 205.93 | 133.887 | 20.593 | |||||
