Engineering ToolBox > ASTM - Sections and Volumes
ASTM standards in sections and volumes
ASTM International is composed of more than 132 technical standards writing committees. Together, they have published more than 9,100 standard specifications, tests, practices, guides, and definitions for materials, products, systems, and services.
ASTM International has published standards dealing with metals, flammability, chemical products, lubricants, fossil fuels, textiles, paint, plastics, rubber, pipe, forensic sciences, electronics, energy, medical devices and countless other topics.
The ASTM Standards are organized in the Sections and Volumes
where each Section contains of several volumes.
Section 1 - Iron and Steel Products
This volume features standards for various types of steel pipe which specify requirements for high-temperature service, ordinary use, and special applications such as fire protection use. Specifications for steel tubes list standard requirements for boiler and super heater tubes, general service tubes, still tubes in refinery service, heat exchanger and condenser tubes, mechanical tubing, and structural tubing. Steel casting specifications call out the standard properties for valves, flanges, fittings, and other pressure containing parts for high-temperature and low-temperature service. Also in this volume, are specifications that cover black, plain end steel pipe for use in the conveyance of fluids under pressure.
Section 2 - Nonferrous Metal Products
Section 3 - Metals Test Methods and Analytical Procedures
Section 4 - Construction
Section 5 - Petroleum Products, Lubricants, and Fossil Fuels
This volume features gaseous fuels, and coal and coke. Under Gaseous Fuels, tables and practices fix standard procedures for sampling and calculating thermo physical properties. In addition, several tests define methods for analyzing the properties of gaseous fuels. And under Coal and Coke, tests and practices establish procedures for evaluating properties of coal and coke such as dustiness, moisture content, plastic properties, and sulphur content.
Section 6 - Paints, Related Coatings, and Aromatics
Section 7 - Textiles
Section 8 - Plastics
Section 9 - Rubber
Section 10 - Electrical Insulation and Electronics
Section 11 - Water and Environmental Technology
Section 12 - Nuclear, Solar, and Geothermal Energy
Section 13 - Medical Devices and Services
Section 14 - General Methods and Instrumentation
Section 15 - General Products, Chemical Specialties, and End Use Products
