Engineering ToolBox > ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards
ASTM International - American Society for Testing and Materials - valve standards:
- ASTM A126-04
Standard Specification for Gray Iron Castings for Valves, Flanges, and Pipe Fittings - ASTM A182/A182M-04
Standard Specification for Forged or Rolled Alloy-Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service - ASTM A338
Standard Specification for Malleable Iron Flanges, Pipe Fittings, and Valve Parts for Railroad, Marine, and Other Heavy Duty Service at Temperatures Up to 650�F (345�C) - ASTM A522/A522M-01
Standard Specification for Forged or Rolled 8 and 9% Nickel Alloy Steel Flanges, Fittings, Valves, and Parts for Low-Temperature Service - ASTM A694/A694M-03
Standard Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service - ASTM A961-04
Standard Specification for Common Requirements for Steel Flanges, Forged Fittings, Valves, and Parts for Piping Applications - ASTM A988/A988M
Standard Specification for Hot Isostatically-Pressed Stainless Steel Flanges, Fittings, Valves, and Parts for High Temperature Service - ASTM A989/A989M
Standard Specification for Hot Isostatically-Pressed Alloy Steel Flanges, Fittings, Valves, and Parts for High Temperature Service - ASTM B61-2
Standard Specification for Steam or Valve Bronze Castings - ASTM B763
Standard Specification for Copper Alloy Sand Castings for Valve Application - ASTM B834
Standard Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel-Chromium-Molybdenum (UNS N08367) and Nickel-Chromium-Molybdenum-Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, and Parts - ASTM C1129
Standard Practice for Estimation of Heat Savings by Adding Thermal Insulation to Bare Valves and Flanges - ASTM F885
Standard Specification for Envelope Dimensions for Bronze Globe Valves NPS 1/4 to 2 - ASTM F992
Standard Specification for Valve Label Plates - ASTM F993
Standard Specification for Valve Locking Devices - ASTM F1020
Standard Specification for Line-Blind Valves for Marine Applications - ASTM F1030
Standard Practice for Selection of Valve Operators - ASTM F1098
Standard Specification for Envelope Dimensions for Butterfly Valves-NPS 2 to 24 - ASTM F1271
Standard Specification for Spill Valves for Use in Marine Tank Liquid Overpressure Protections Applications - ASTM F1370
Standard Specification for Pressure-Reducing Valves for Water Systems, Shipboard - ASTM F1394
Standard Test Method for Determination of Particle Contribution from Gas Distribution System Valves - ASTM F1565
Standard Specification for Pressure-Reducing Valves for Steam Service - ASTM F1792
Standard Specification for Special Requirements for Valves Used in Gaseous Oxygen Service - ASTM F1793
Standard Specification for Automatic Shut-Off Valves (Also Known as Excess Flow Valves, EFV) for Air Or Nitrogen Service - ASTM F1794
Standard Specification for Hand-Operated, Globe-Style Valves for Gas (Except Oxygen Gas), and Hydraulic Systems - ASTM F1795
Standard Specification for Pressure-Reducing Valves for Air or Nitrogen Systems - ASTM F1802
Standard Test Method for Performance Testing of Excess Flow Valves - ASTM F1970
Standard Specification for Special Engineered Fittings, Appurtenances or Valves for use in Poly (Vinyl Chloride) (PVC) or Chlorinated Poly (Vinyl Chloride) (CPVC) Systems - ASTM F1985
Standard Specification for Pneumatic-Operated, Globe-Style, Control Valves - ASTM F2138
Standard Specification for Excess Flow Valves for Natural Gas Service - ASTM F2215
Standard Specification for Balls, Bearings, Ferrous and Nonferrous for Use in Bearings, Valves, and Bearing Applications - ASTM F2324
Standard Test Method for Prerinse Spray Valves
