Engineering ToolBox > Bursting Pressure
Barlow's formula can be used to estimate burst pressure of pipes or tubes.
P = 2 s t / [(do - 2 t) SF] (1)
P = max. working pressure (psig)
s = material strength (psi)
t = wall thickness (in)
do = outside diameter (in)
SF = safety factor (in general 1.5 to 10)
The Barlow's estimate is based on ideal conditions at room temperature.
The strength of a material is determined by the tension test, which measure the tension force and the deformation of the test specimen.
Strength of some common materials:
| Material | Yield Strength (psi) | Ultimate Strength (psi) |
| Stainless Steel, 304 | 30,000 | 75,000 |
| 6 Moly, S31254 | 45,000 | 98,000 |
| Duplex, S31803 | 65,000 | 90,000 |
| Nickel, N02200 | 15,000 | 55,000 |
