Engineering ToolBox > Stresses and Deflections in Beams
Beam and shaft deflection and stress calculator
The calculator below can be used to calculate maximum stress and deflection of beams with one or uniform loads.
Beam Supported at Both Ends, Uniform Load
beam stress deflection uniform load
Maximum Stress
Maximum stress in a beam with uniform load supported at both ends can be calculated as
σ = y q L2 / 8 I (1)
σ = maximum stress (Pa (N/m2), psi)
y = Perpendicular distance from to neutral axis (m, in)
q = uniform load (N/m, lb/in)
L = length of beam (m, in)
I = moment of Inertia (m4, in4)
Maximum deflection can be expressed as
δ = 5 q L4 / E I 384 (2)
δ = maximum deflection (m, in)
E = modulus of elasticity (Pa (N/m2), psi)
Metric Units
q - Uniform load (N/mm)
L - Length of Beam (mm)
I - Moment of Inertia (mm4)
E - Modulus of Elasticity (N/mm2))
y - Perpendicular distance from to neutral axis (mm)
Imperial Units
q - Load (lb/in)
L - Length of Beam (in)
I - Moment of Inertia (in4)
E - Modulus of Elasticity (psi)
y - Perpendicular distance from to neutral axis (in)
Example - Beam with Uniform Load, English Units
The maximum stress in a "W 12 x 35" Steel Wide Flange beam, 100 inches long, moment of inertia 285 in4, modulus of elasticity 29000000 psi, with uniform load 100 lb/in can be calculated like
σ = y q L2 / 8 I
    = 6.25 (in) 100 (lb/in) 1002 (in2) / 8 285 (in4)
    = 2741 (lb/in2 (psi))
The maximum deflection can be calculated as
    = 5 100 (lb/in) 1004 (in4) / 29000000 (lb/in2) 285 (in4) 384
    = 0.016 in
Beam Supported at Both Ends, Load at Center
beam stress deflection single load
Maximum Stress
σ = y F L / 4 I (1)
F = load (N, lb)
δ = F L3 / E I 48 (2)
Metric Units
F - Load (N)
Imperial Units
F - Load (lb)
Example - Beam with a Single Center Load
The maximum stress in a "W 12 x 35" Steel Wide Flange beam, 100 inches long, moment of inertia 285 in4, modulus of elasticity 29000000 psi, with a center load 10000 lb can be calculated like
σ = y F L / 4 I
    = 6.25 (in) 10000 (lb) 100 (in) / 4 285 (in4)
    = 5482 (lb/in2 (psi))
δ = F L3 / E I 48
    = 10000 (lb/in) 1003 (in3) / 29000000 (lb/in2) 285 (in4) 48
    = 0.025 in
