Engineering ToolBox > Boiler Efficiency
Boiler efficiency, combustion, gross and net calorific value
Boiler Efficiency may be indicated by
Boiler Efficiency is in general indicated by either Thermal Efficiency or Fuel to Fluid Efficiency depending the context.
Boiler Efficiency
Boiler Efficiency related to the boilers energy output to the boilers energy input can be expressed as:
Boiler efficiency (%) = Heat exported by fluid (water, steam ..) / Heat provided by fuel x 100 (1)
Heat Exported from the Boiler to the Fluid
For a fluid as water the heat exported by the boiler can be expressed as:
q = ( m / t ) cp dT (2)
q = Heat exported (kJ/s, kW)
m / t = mass flow (kg/s)
cp = specific heat capacity (kJ/kg oC)
dT = temperature difference between inlet and outlet of the boiler (oC)
For a steam boiler the heat supplied by evaporating the water at saturation temperature can be expressed as:
q = ( m / t ) he (3)
he = evaporation energy in the steam at the pressure the boiler is running (kJ/kg)
Heat Provided by Fuel
The energy provided by fuel may be expressed in two ways 'Gross' or 'Net' calorific value.
Gross Calorific Value
This is the theoretical total of the energy in the fuel. The gross calorific value of the fuel includes the energy used for evaporating the water in the combustion process. The flue gases from boilers are in general not condensed. The actual amount of heat available to the boiler plant is therefore reduced.
An accurate control of the amount of air is essential to the boiler efficiency. To much air will cool the furnace and carry away useful heat. Too little air and the combustion will be incomplete. Unburned fuel will be carried over and smoke may be produced.
Net calorific value
This is the calorific value of the fuel, excluding the energy in the water vapor discharged in the combustion process to the stack. The combustion process can be expressed as:
[C + H (fuel)] + [O2 + N2 (Air)] -> (Combustion Process) -> [CO2 + H2O + N2 (Heat)]
C = Carbon
H = Hydrogen
O = Oxygen
N = Nitrogen
In general it is possible to use the approximation:
net calorific value = gross calorific value - 10%
