Engineering ToolBox > Bulk Modulus and Fluid Elasticity
An introduction to and a definition of the Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids
The Bulk Modulus Elasticity is a material property characterizing the compressibility of a fluid - how easy a unit of the fluid volume can be changed when changing the pressure working upon it.
bulk modulus elasticity
The Bulk Modulus Elasticity can be expressed as
E = - dp / (dV / V) (1)
E = bulk modulus elasticity
dp = differential change in pressure on the object
dV = differential change in volume of the object
V = initial volume of the object
The Bulk Modulus Elasticity can be alternatively expressed as
E = dp / (dρ / ρ) (2)
dρ = differential change in density of the object
ρ = initial density of the object
An increase in the pressure will decrease the volume (1). A decrease in the volume will increase the density (2).
A large Bulk Modulus indicate a relative incompressible fluid.
Bulk Modulus for some common fluids can be found in the table below:
Bulk Modulus - E Imperial Units - BG
(psi, lbf/in2) x 105
SI Units
(Pa, N/m2) x 109
Carbon Tetrachloride 1.91 1.32
Ethyl Alcohol 1.54 1.06
Gasoline 1.9 1.3
Glycerin 6.56 4.52
Mercury 4.14 2.85
SAE 30 Oil 2.2 1.5
Seawater 3.39 2.34
Water 3.12 2.15
