Engineering ToolBox > Capillarity
Capillarity or capillary action is the ability of a narrow tube to draw a liquid upwards against the force of gravity
Capillarity or capillary action is the ability of a narrow tube to draw a liquid upwards against the force of gravity.
capillarity action
The height of liquid in a tube due to capillarity can be expressed as
h = 2 σ cosθ / (ρ g r) (1)
h = height of liquid (ft, m)
σ = surface tension (lb/ft, N/m)
θ = contact angle
ρ = density of liquid (lb/ft3, kg/m3)
g = acceleration due to gravity (32.174 ft/s2, 9.81 m/s2)
r = radius of tube (ft, m)
Surface Tension
Surface tension is typically measured in dynes/cm or N/m.
Liquid Surface Tension
N/m dynes/cm
Ethyl Alcohol 0.0223 22.3
Mercury 0.465 465
Water 20oC 0.0728 72.75
Water 100oC 0.0599 58.9
