Engineering ToolBox > Center of Gravity
Center of gravity of some common bodies
The center of gravity of a volume, area or line is the point at which if the body where suspended would be in balance.
For a symmetrical body of a uniform material the center of gravity would be in the geometric center.
Perimeter
center of gravity - perimeter
The center of gravity is the center of the circle inscribed in triangle ABC (middle points of the sides of the triangle).
The distance d can be calculated as
d = h (b + c) / 2 (a + b + c) (1)
Area or Triangel
center of gravity - area
The center of gravity is at the intersection of lines BE and AD. The distance a can be calculated as
a = h / 3 (2)
Parallelogram
center of gravity - parallelogram
The center of gravity of a parallelogram is at the intersection of the diagonals.
Trapezoid
center of gravity - trapezoid
Tee center of gravity of can be estimated by dividing the trapezoid in two triangles.
The center of gravity will be in the intersection between the middle line CD and the line between the triangles centers of gravity.
