Engineering ToolBox > Epoxy - Chemical Resistance
Epoxy (polyepoxide) is an epoxide polymer that cures when mixed with a catalyzing agent or "hardener". Epoxy resin have an excellent electrical, thermal, and chemical resistance. It is common to increase the strength of epoxy with fibrous reinforcement or mineral fillers. The variety of combinations of epoxy resins and reinforcements provides a wide latitude in properties obtainable in molded parts.
The table below can be used as an indication of epoxy resistance to chemical compounds. Always check the chemical resistance with the epoxy manufacturer.
| Chemical Product | Approximate Maximum Temperature | |
| (oC) | (oF) | |
| Acetic Acid | 25 - 40 | 75 - 100 |
| Acetone | 25 - 80 | 75 - 175 |
| Acrylic Acid | 40 - 50 | 100 - 120 |
| Adipic acid | 110 - 120 | 225 - 250 |
| Alcohol - Ethyl | 50 - 80 | 120 - 175 |
| Alcohol - Isopropyl | 40 - 80 | 100 - 175 |
| Alcohol - Methyl | 25 - 65 | 75 - 150 |
| Alcohol - Secondary Butyl | 40 - 80 | 100 - 175 |
| Aluminum Chloride | 65 - 150 | 150 - 300 |
| Aluminum Fluoride | 25 - 65 | 75 - 150 |
| Aluminum Hydroxide | 65 - 95 | 150 - 200 |
| Aluminum Nitrate | 65 - 120 | 150 - 250 |
| Aluminum Sulfate | 100 - 150 | 210 - 300 |
| Alums | 110 - 150 | 225 - 300 |
| Allyl chloride | 25 - 50 | 75 - 120 |
| Ammonia - Wet | 50 - 65 | 125 - 150 |
| Ammonia - Gas | 65 - 110 | 150 - 225 |
| Ammonium Carbonate | 65 - 95 | 150 - 200 |
| Ammonium Chloride | 65 - 130 | 150 - 270 |
| Ammonium Fluoride | 25 - 65 | 75 - 150 |
| Ammonium Hydroxide | 40 - 95 | 100 - 200 |
| Ammonium Nitrate | 95 - 120 | 200 - 250 |
| Ammonium Phosphate | 65 - 95 | 150 - 200 |
| Ammonium Sulfate | 95 - 150 | 200 - 300 |
| Amyl acetate | 25 - 50 | 75 - 120 |
| Aniline | 25 - 40 | 75 - 100 |
| Antimony trichloride | 65 - 104 | 150 - 220 |
| Barium Carbonate | 95 - 120 | 200 - 250 |
| Barium Chloride | 100 - 120 | 210 - 250 |
| Barium Hydroxide | 80 - 104 | 175 - 200 |
| Barium Sulfate | 100 - 120 | 210 - 250 |
| Barium Sulfide | 100 - 150 | 210 - 300 |
| Beer | 95 - 110 | 200 - 225 |
| Benzene | 40 - 65 | 100 - 150 |
| Benzoic Acid | 40 - 104 | 100 - 220 |
| Black Pulp Liqueur | 40 - 110 | 100 - 225 |
| Borax | 110 - 120 | 225 - 250 |
| Boric acid | 95 - 110 | 200 - 225 |
| Bromic acid | 65 | 150 |
| Bromine water | 40 - 65 | 100 - 150 |
| Butadiene gas | 40 - 65 | 100 - 150 |
| Butane gas | 25 - 65 | 75 - 150 |
| Butyl acetate | 65 | 150 |
| Butyl cellosolve | 65 | 150 |
| Butyric Acid | 65 - 95 | 150 - 200 |
| Calcium Bisulfite | 95 - 130 | 200 - 270 |
| Calcium Carbonate | 65 - 150 | 150 - 300 |
| Calcium Chlorate | 65 - 95 | 150 - 200 |
| Calcium Chloride | 100 - 150 | 210 - 300 |
| Calcium Hydroxide | 65 - 95 | 150 - 200 |
| Calcium Hypochlorite | 40 - 65 | 100 - 150 |
| Calcium Nitrate | 65 - 120 | 150 - 250 |
| Calcium Sulfate | 95 - 120 | 200 - 250 |
| Carbon dioxide gas | 110 - 120 | 225 - 250 |
| Carbon Tetrachloride | 40 - 65 | 100 - 150 |
| Carbonic Acid | 65 - 80 | 150 - 175 |
| Citric Acid | 95 - 120 | 200 - 250 |
| Chlorine Dioxide, Wet Gas | 25 | 75 |
| Chlorine Gas | 50 | 125 |
| Chloroacetic Acid | 40 - 95 | 100 - 200 |
| Chromic Acid | 25 - 65 | 75 - 150 |
| Chromic Fluoride | 25 | 75 |
| Copper Chloride | 65 - 120 | 150 - 250 |
| Copper Fluoride | 95 - 120 | 200 - 250 |
| Copper Nitrate | 65 - 120 | 150 - 250 |
| Dichlorobenzene (ortho) | 40 - 65 | 100 - 150 |
| Diesel Fuel | 100 - 120 | 210 - 250 |
| Ethyl acetate | 25 - 65 | 75 - 150 |
| Ethyl cellosolve | 40 - 65 | 100 - 150 |
| Ethyl chloride | 25 - 27 | 75 - 80 |
| Ethylene glycol | 95 - 130 | 200 - 270 |
| Fatty Acids | 95 - 110 | 200 - 225 |
| Ferric Chloride | 65 - 150 | 150 - 300 |
| Ferric Nitrate | 65 - 120 | 150 - 250 |
| Ferric Sulfate | 95 - 110 | 200 - 225 |
| Ferrous Chloride | 80 - 120 | 175 - 250 |
| Ferrous Sulfate | 95 - 110 | 200 - 225 |
| Fluorine gas | 25 | 75 |
| Fluoboric acid | 95 | 200 |
| Fluosilicic acid | 40 - 95 | 100 - 200 |
| Formaldehyde | 25 - 65 | 75 - 150 |
| Formic Acid | 40 - 60 | 100 - 140 |
| Freon | 25 - 65 | 75 - 150 |
| Gas, Natural | 95 - 110 | 200 - 225 |
| Gasoline | 65 - 110 | 150 - 225 |
| Glucose | 95 - 120 | 200 - 250 |
| Glycerine | 100 - 150 | 210 - 300 |
| Glycol Ethylene | 95 | 200 |
| Heptane | 65 - 95 | 150 - 200 |
| Hexane | 25 - 65 | 75 - 150 |
| Hexylene glycol alcohol | 65 | 150 |
| Hydraulic Fluid | 95 - 110 | 200 - 225 |
| Hydrobromic Acid | 40 - 65 | 100 - 150 |
| Hydrochloric acid | 25 - 95 | 75 - 200 |
| Hydrocyanic Acid | 50 | 120 |
| Hydrofluoric Acid | 25 | 75 |
| Hydrogen Peroxide | 27 - 65 | 80 - 150 |
| Hydrogen Sulfide | 65 - 120 | 150 - 250 |
| Hypochlorous acid | 50 - 95 | 120 - 200 |
| Jet Fuel | 65 - 120 | 150 - 250 |
| Kerosene | 65 - 120 | 150 - 250 |
| Lactic Acid | 95 - 110 | 200 - 225 |
| Lauric acid | 95 - 110 | 200 - 225 |
| Lead acetate | 65 - 120 | 150 - 250 |
| Levulinic acid | 95 - 120 | 200 - 250 |
| Magnesium Carbonate | 65 - 120 | 150 - 250 |
| Magnesium Chloride | 100 - 130 | 210 - 270 |
| Magnesium Hydroxide | 50 - 130 | 120 - 270 |
| Magnesium Nitrate | 100 - 150 | 210 - 300 |
| Magnesium Sulfate | 65 - 130 | 150 - 270 |
| Maleic Acid | 65 - 104 | 150 - 220 |
| Mercury | 110 - 130 | 225 - 270 |
| Methyl Ethyl Ketone | 25 - 65 | 75 - 150 |
| Naphtha | 95 - 120 | 200 - 250 |
| Naphthalene | 65 - 95 | 150 - 200 |
| Nickel Chloride | 100 - 150 | 210 - 300 |
| Nickel Nitrate | 95 - 120 | 200 - 250 |
| Nitric Acid | 25 - 50 | 75 - 120 |
| Oil - Castor | 95 - 110 | 200 - 225 |
| Oil - Crude | 100 - 120 | 210 - 250 |
| Oil - Mineral | 100 - 130 | 210 - 270 |
| Oleic acid | 95 - 110 | 200 - 225 |
| Oxalic Acid | 65 - 120 | 150 - 250 |
| Phenol | 25 - 65 | 75 - 150 |
| Phosphoric Acid | 25 - 110 | 75 - 225 |
| Picric Acid | 27 - 40 | 75 - 100 |
| Potassium Bicarbonate | 65 - 130 | 150 - 270 |
| Potassium Bromide | 95 - 110 | 200 - 225 |
| Potassium Carbonate | 40 - 120 | 100 - 250 |
| Potassium Chloride | 100 - 150 | 210 - 300 |
| Potassium Dichromate | 95 - 120 | 200 - 250 |
| Potassium Hydroxide | 40 - 95 | 100 - 200 |
| Potassium Nitrate | 95 - 150 | 200 - 300 |
| Potassium Sulfate | 100 - 130 | 210 - 270 |
| Propane | 25 - 65 | 75 - 150 |
| Silicic Acid | 95 - 120 | 200 - 250 |
| Silver Nitrate | 65 - 120 | 150 - 250 |
| Soaps | 95 - 120 | 200 - 250 |
| Sodium Acetate | 65 - 120 | 150 - 250 |
| Sodium Bicarbonate | 95 - 135 | 200 - 275 |
| Sodium Bisulfate | 65 - 120 | 150 - 250 |
| Sodium Bromide | 95 - 120 | 200 - 250 |
| Sodium Carbonate | 40 - 95 | 100 - 205 |
| Sodium Chlorate | 80 - 120 | 175 - 250 |
| Sodium Chloride | 100 - 150 | 210 - 300 |
| Sodium Cyanide | 110 - 120 | 225 - 250 |
| Sodium Dichromate | 95 - 120 | 200 - 250 |
| Sodium Ferrocyanide | 95 - 150 | 200 - 300 |
| Sodium Fluoride | 65 - 120 | 150 - 250 |
| Sodium Hydroxide | 40 - 95 | 100 - 200 |
| Sodium Hypochlorite | 25 | 75 |
| Sodium Nitrate | 95 - 150 | 200 - 300 |
| Sodium Phospate | 95 | 200 |
| Sodium Silicate | 65 - 104 | 150 - 220 |
| Sodium Sulfate | 95 - 150 | 200 - 300 |
| Sodium Sulfite | 95 | 200 |
| Sodium Thiosulfate | 65 | 150 |
| Stannic Chloride | 65 - 130 | 150 - 270 |
| Stearic Acid | 65 - 110 | 150 - 225 |
| Sulfamic Acid | 40 - 65 | 100 - 150 |
| Sulfite Liquor | 65 | 150 |
| Sulfur Dioxide | 65 - 120 | 150 - 250 |
| Sulfuric Acid | 25 - 95 | 75 - 205 |
| Sulfurous Acid 10% | 25 - 95 | 75 - 200 |
| Tannic Acid | 95 - 110 | 200 - 225 |
| Tartaric Acid | 65 - 120 | 150 - 250 |
| Toluene | 40 - 65 | 100 - 150 |
| Triethanolamine | 40 - 65 | 100 - 150 |
| Trisodium Phosphate | 40 - 95 | 100 - 200 |
| Tung oil | 95 | 200 |
| Turpentine | 40 - 65 | 100 - 150 |
| Urea | 65 - 95 | 150 - 200 |
| Vinegar | 65 - 95 | 150 - 200 |
| Vinyl acetate | 25 - 65 | 75 - 150 |
| Water - Deionized | 100 | 212 |
| Water - Fresh | 95 - 120 | 200 - 250 |
| Water - Sea | 100 - 130 | 210 - 270 |
| Xylene | 50 - 65 | 125 - 150 |
| Zinc Chloride | 100 - 120 | 210 - 250 |
