Engineering ToolBox > Polyester - Chemical Resistance
Polyester resins combine excellent mechanical, electrical and thermal properties with very good chemical resistance and dimensional stability. Chemical resistance to some common products are shown in the table below.
| Chemical Product | Polyester | |
| 60oF (15oC) | 150oF (66oC) | |
| Acetic Acid 0-25% (vinegar) | R | max 125 |
| Acetic Acid 25-50% | R | NR |
| Alcohol - Butyl | NR | NR |
| Alcohol - Isopropyl | max 150 | |
| Alcohol - Isopropyl 100% | NR | NR |
| Alcohol - Secondary Butyl | NR | NR |
| Alum (Aluminum Sulfate) | R | R |
| Aluminum Chloride | R | max 120 |
| Aluminum Potassium Sulfate | R | R |
| Ammonium Bicarbonate | R | NR |
| Ammonium Hydroxide 5% | R | NR |
| Ammonium Hydroxide 10% | NR | NR |
| Ammonium Hydroxide 20% | NR | NR |
| Ammonium Nitrate | R | R |
| Ammonium Persulfate | NR | NR |
| Ammonium Phosphate | NR | NR |
| Ammonium Sulfate | R | R |
| Barium Acetate | NR | NR |
| Barium Carbonate | R | NR |
| Barium Chloride | R | max 200 |
| Barium Sulfate | R | R |
| Barium Sulfide | NR | NR |
| Beer | R | NR |
| Benzoic Acid | R | NR |
| Benzyl Alcohol | NR | NR |
| Butylene Glycol | R | R |
| Butyric Acid 0-50% | R | NR |
| Cadmium Chloride | R | NR |
| Calcium Bisulfate | R | R |
| Calcium Carbonate | R | NR |
| Calcium Chlorate | R | R |
| Calcium Chloride | R | R |
| Calcium Hydroxide | R | NR |
| Calcium Hypochlorite | R | NR |
| Calcium Nitrate | R | R |
| Calcium Sulfate | R | R |
| Calcium Sulfite | R | R |
| Caprylic Acid | R | NR |
| Carbon Dioxide | R | R |
| Carbon Monoxide | R | R |
| Carbonic Acid | R | R |
| Chlorine Dioxide/Air | R | NR |
| Chlorine - Dry Gas | R | NR |
| Chlorine, Wet Gas | NR | NR |
| Chlorine Water | NR | NR |
| Chloroacetic Acid 0-50% | NR | NR |
| Chromium Sulfate | R | R |
| Citric Acid | R | R |
| Coconut Oil | R | NR |
| Copper Chloride | R | R |
| Copper Cyanide | NR | NR |
| Copper Fluoride | NR | NR |
| Copper Nitrate | R | R |
| Copper Sulfate | R | R |
| Corn Oil | R | NR |
| Corn Starch-Slurry | R | NR |
| Corn Sugar | R | NR |
| Cottonseed Oil | R | NR |
| Crude Oil, Sour | R | NR |
| Crude Oil, Sweet | R | NR |
| Cyclohexane | R | NR |
| Di-Ammonium Phosphate | NR | NR |
| Dibutyl Ether | NR | NR |
| Diesel Fuel | R | NR |
| Diethylene Glycol | R | NR |
| Dimenthyl Phthalate | NR | NR |
| Dioctyl Phthalate | NR | NR |
| Dipropylene Glycol | R | NR |
| Ethylene Glycol | R | R |
| Fatty Acids | R | R |
| Ferric Chloride | R | R |
| Ferric Nitrate | R | R |
| Ferric Sulfate | R | R |
| Ferrous Chloride | R | R |
| Ferrous Nitrate | R | R |
| Ferrous Sulfate | R | R |
| Fluoboric Acid 10% | NR | NR |
| Fluosilicic Acid 0-20% | NR | NR |
| Formaldehyde | R | NR |
| Formic Acid 10% | R | NR |
| Fuel Oil | R | NR |
| Gas, Natural | R | NR |
| Gasoline, Auto | R | NR |
| Gasoline Aviation | R | NR |
| Gasoline, Ethyl | R | NR |
| Gasoline, Sour | R | NR |
| Glyconic, Acid | R | NR |
| Glucose | R | R |
| Glycerin | R | R |
| Glycol - Propylene | R | R |
| Glycolic Acid 70% | R | NR |
| Heptanes | R | NR |
| Hexane | R | NR |
| Hexalene Glycol | R | R |
| Hydraulic Fluid | R | NR |
| Hydrobromic Acid 0-25% | R | NR |
| Hydrocyanic Acid | R | NR |
| Hydrofluosilicic Acid 10% | NR | NR |
| Hydrogen Chloride, Wet Gas | NR | NR |
| Hydrogen Fluoride, Vapor | R | max 95 |
| Hydrogen Peroxide 35% | R | max 120 |
| Hydrogen Sulfide Dry | R | max 250 |
| Hypochlorous Acid 0-10% | R | max 104 |
| Isopropyl Palmitate | R | max 180 |
| Kerosene | R | max 120 |
| Lactic Acid | R | max 200 |
| Lead Acetate | R | max 160 |
| Magnesium Carbonate | R | max 160 |
| Magnesium Chloride | R | max 220 |
| Magnesium Nitrate | R | max 160 |
| Magnesium Sulfate | R | max 200 |
| Mercuric Chloride | R | max 212 |
| Mercurous Chloride | R | max 212 |
| Mineral Oils | R | max 180 |
| Naphtha | R | R |
| Naphthalene | R | NR |
| Nickel Chloride | R | NR |
| Nickel Nitrate | R | R |
| Nickel Sulfate | R | R |
| Nitric Acid 0-5% | R | R |
| Octanoic Acid | R | NR |
| Oil, Sour Crude | R | R |
| Oil, Sweet Crude | R | R |
| Oleic Acid | R | R |
| Olive Oil | R | R |
| Oxalic Acid | R | R |
| Phosphoric Acid | R | R |
| Phosphoric Acid Fumes | R | R |
| Phosphorous Pentoxide | R | R |
| Phthalic Acid | R | R |
| Pickling Acids | R | R |
| Picric Acid, Alcoholic | R | R |
| Polyvinyl Acetate Latex | R | NR |
| Polyvinyl Alcohol | R | NR |
| Potassium Aluminum Sulfate | R | max 170 |
| Potassium Bicarbonate | R | NR |
| Potassium Carbonate | R | NR |
| Potassium Chloride | R | R |
| Potassium Ferro cyanide | R | R |
| Potassium Nitrate | R | R |
| Potassium Permanganate | R | NR |
| Potassium Persulfate | R | NR |
| Pulp Paper Mill Effluent | R | NR |
| Pyridine | NR | NR |
| Silver Nitrate | R | R |
| Soaps | R | NR |
| Sodium Acetate | R | NR |
| Sodium Benzoate | R | NR |
| Sodium Bifluoride | R | NR |
| Sodium Bisulfate | R | R |
| Sodium Bisulfite | R | R |
| Sodium Bromide | R | R |
| Sodium Carbonate 0-25% | R | NR |
| Sodium Chlorate | R | NR |
| Sodium Chloride | R | NR |
| Sodium Chlorite 25% | R | NR |
| Sodium Cyanide | R | NR |
| Sodium Dichromate | R | R |
| Sodium Di-Phosphate | R | R |
| Sodium Ferricyanide | R | R |
| Sodium Hydroxide 0-5% | R | R |
| Sodium Hydrosulfide | R | NR |
| Sodium Hypochlorite | R | NR |
| Sodium Lauryl Sulfate | R | R |
| Sodium Mono-Phosphate | R | R |
| Sodium Nitrate | R | R |
| Sodium Silicate | R | NR |
| Sodium Sulfate | R | R |
| Sodium Sulfide | R | NR |
| Sodium Sulfite | R | NR |
| Sodium Tetraborate | R | R |
| Sodium Thiosulfate | R | NR |
| Sodium Tripolyphosphate | R | NR |
| Sodium Xylene Sulfonate | R | NR |
| Sodium Solutions | R | NR |
| Sodium Crude Oil | R | R |
| Soya Oil | R | R |
| Stannic Chloride | R | R |
| Stannous Chloride | R | R |
| Stearic Acid | R | R |
| Sugar, Beet and Cane Liquor | R | NR |
| Sugar, Sucrose | R | R |
| Sulfamic Acid | R | NR |
| Sulfated Detergents | R | NR |
| Sulfuric Acid 0-30% | R | R |
| Sulfuric Acid 30-50% | NR | NR |
| Sulfuric Acid 50-70% | R | max 150 |
| Sulfurous Acid 10% | NR | NR |
| Superphosphoric Acid | R | NR |
| Tall Oil | R | NR |
| Tannic Acid | R | NR |
| Tartaric Acid | R | R |
| Toluene | NR | NR |
| Trichloro Acetic Acid 50% | R | NR |
| Tridecylbenzene Sulfonate | R | NR |
| Trisodium Phosphate | R | NR |
| Urea | R | NR |
| Vegetable Oils | R | R |
| Vinegar | R | R |
| Water - Deionized | R | R |
| Water - Demineralized | R | R |
| Water - Distilled | R | R |
| Water - Fresh | R | R |
| Water - Salt | R | R |
| Water - Sea | R | R |
| White Liquor - Pulp Mill | R | NR |
| Xylene | NR | NR |
| Zinc Chlorate | R | R |
| Zinc Nitrate | R | R |
| Zinc Sulfate | R | R |
