Engineering ToolBox > Classifications of Pumps
Selecting between Centrifugal Pumps and Positive Displacement Pumps
Pumps are in general classified as Centrifugal Pumps (or Roto-dynamic pumps) and Positive Displacement Pumps.
Centrifugal Pumps (Roto-dynamic pumps)
The centrifugal or roto-dynamic pump produce a head and a flow by increasing the velocity of the liquid through the machine with the help of a rotating vane impeller. Centrifugal pumps include radial, axial and mixed flow units.
Centrifugal pumps can further be classified as
The positive displacement pump operates by alternating of filling a cavity and then displacing a given volume of liquid. The positive displacement pump delivers a constant volume of liquid for each cycle against varying discharge pressure or head.
The positive displacement pump can be classified as:
Selecting between Centrifugal or Positive Displacement Pumps
Selecting between a Centrifugal Pump or a Positive Displacement Pump is not always straight forward.
Flow Rate and Pressure Head
The two types of pumps behave very differently regarding pressure head and flow rate:
Capacity and Viscosity
Another major difference between the pump types is the effect of viscosity on the capacity:
Liquids with high viscosity fills the clearances of a Positive Displacement Pump causing a higher volumetric efficiency and a Positive Displacement Pump is better suited for high viscosity applications. A Centrifugal Pump becomes very inefficient at even modest viscosity.
Mechanical Efficiency
The pumps behaves different considering mechanical efficiency as well.
Net Positive Suction Head - NPSH
Another consideration is the Net Positive Suction Head NPSH.
