Engineering ToolBox > Closed Expansion Tank Sizing
The diagrams below can be used to estimate the size of a closed expansion tank at low temperatures.
The diagram below can be used to estimate the size of a closed expansion tank at low temperatures.
For initial and maximum pressures different from above - multiply the tank size with the a correction factor estimated from the diagram below:
