Engineering ToolBox > Combustion Processes and Combustion Efficiency
Combustion is the oxidation of carbon-containing material in the presence of sufficient oxygen to complete the process.
C + O2 > CO2
Typical combustion process efficiencies can be summarized as
The performance of a furnace is usually assessed by the following indices
μt = 100 Eo / Ei (1)
μt = thermal efficiency
Eo = fuel energy output (W, Btu/h)
Ei = fuel energy input (W, Btu/h)
AFUE measures the annual amount of heat actually delivered compared to the amount of fuel supplied to the furnace.
AFUE = 100 Eao / Eai (2)
AFUE = annual fuel utilization efficiency
Eao = annual fuel energy output (W, Btu/h)
Eai = annual fuel energy input (W, Btu/h)
Steady State Efficiency measures how efficiently a furnace converts fuel to heat, once the furnace has warmed up and is running steadily and can be expressed as
SSE= 100 (Ei - El) / Ei (2)
SSE = steady-state efficiency
El = fuel energy loss (W, Btu/h)
