Engineering ToolBox > Fluid Mechanics and Conservation of Mass
The Law of Mass Conservation states that"a mass can neither be created nor destroyed".
The inflows, outflows and change in storage of mass in a system - must be in balance.
The mass flow inn and out of a control volume (through a physical or virtual boundary) can for an limited increment of time be expressed as:
dM = ρi vi Ai dt - ρo vo Ao dt (1)
dM = change of storage mass in the system (kg)
ρ = density (kg/m3)
v = speed (m/s)
A = area (m2)
dt = an increment of time (s)
If the outflow is higher then the inflow - the change in mass dM is negative - and the mass in the system decreases. And obvious - the mass in a system increases if inflow is higher than the outflow.
The Law of Mass Conservation is a fundament in fluid mechanics and a basis for the Equation of Continuity and the Bernoulli Equation.
Water with density 1000 kg/m3 flows into a tank through a pipe of 50 mm inside diameter. The velocity in the pipe is 2 m/s. The water flows out of the tank through a pipe with inside diameter 30 mm with a velocity of 2,5 m/s.
Using equation (1) the change in the tank content after 20 minutes can calculated as:
dM = (1000 kg/m3)(2 m/s)(3,14 x 0.05 (m) x 0.05 (m) / 4)(20 x 60 s) - (1000 kg/m3)(2.5 m/s)(3.14 x 0.03 (m) x 0.03 (m) / 4)(20 x 60 s)
= 2590.5 kg
