Engineering ToolBox > Leakage Classifications of Control Valves
Classification of seat leakage through control valves
Control valves are designed to throttle and not necessary to close 100%.
A control valve's ability to shut off has to do with many factors as the type of valves for instance. A double seated control valve have very poor shut off capability. The guiding, seat material, actuator thrust, pressure drop, and the type of fluid can all play a part in how well a particular control valve shuts off.
Seat Leakage Classifications
There are actually six different seat leakage classifications as defined by ANSI/FCI 70-2 1976(R1982) .
The most common used are
CLASS IV is also known as metal to metal. It is the kind of leakage rate you can expect from a valve with a metal plug and metal seat.
CLASS Vl is known as a soft seat classification. Soft Seat Valves are those where either the plug or seat or both are made from some kind of composition material such as Teflon or similar.
Valve Leakage Classifications
Class I - Valve Leakage Classifications
Identical to Class II, III, and IV in construction and design intent, but no actual shop test is made. Cass I is also known as dust tight and can refer to metal or resilient seated valves.
Class II - Valve Leakage Classifications
Intended for double port or balanced singe port valves with a metal piston ring seal and metal to metal seats.
Typical constructions:
Class III - Valve Leakage Classifications
Intended for the same types of valves as in Class II.
Class IV - Valve Leakage Classifications
Intended for single port and balanced single port valves with extra tight piston seals and metal to-metal seats.
Class V - Valve Leakage Classifications
Intended for the same types of valves as Class IV.
Class Vl - Valve Leakage Classifications
Class Vl is known as a soft seat classification. Soft Seat Valves are those where the seat or shut-off disc or both
are made from some kind of resilient material such as Teflon. Intended for resilient seating valves.
Port Diameter Bubbles per minute ml per minute
inches Millimeters
1 25 1 0.15
1 1/2 38 2 0.30
2 51 3 0.45
2 1/2 64 4 0.60
3 76 6 0.90
4 102 11 1.70
6 152 27 4.00
8 203 45 6.75
10 254 63 9
12 305 81 11.5
Control Valve Leakage Classification - Overview
Leakage Class Designation Maximum Leakage Allowable Test Medium Test Pressure Testing Procedures Required for Establishing Rating
I x x x No test required
II 0.5% of rated capacity Air or water at 50 - 125o F
(10 - 52oC)
45 - 60 psig or maximum operating differential whichever is lower 45 - 60 psig or maximum operating differential whichever is lower
III 0.1% of rated capacity As above As above As above
IV 0.01% of rated capacity As above As above As above
V 0.0005 ml per minute of water per inch of port diameter per psi differential Water at 50 to125oF (10 to 52oC) Maximum service pressure drop across valve plug not to exceed ANSI body rating Maximum service pressure drop across valve plug not to exceed ANSI body rating
VI Not to exceed amounts shown in the table above Air or nitrogen at 50 to 125o F (10 to 52oC) 50 psig or max rated differential pressure across valve plug whichever is lower Actuator should be adjusted to operating conditions specified with full normal closing thrust applied to valve plug seat
