Engineering ToolBox > Water Control Valves - Calculating Kv Values
The table below can be used to estimate the Kv values for process control valves used in water systems.
| Kv | Water flow | |||||||||||
| Pressure drop | (kg/h) | |||||||||||
| 36 | 72 | 108 | 144 | 180 | 360 | 720 | 1080 | 1440 | 1800 | 3600 | ||
| (kPa) | (bar) | (kg/s) | ||||||||||
| 0.01 | 0.02 | 0.03 | 0.04 | 0.05 | 0.1 | 0.2 | 0.3 | 0.4 | 0.5 | 1 | ||
| 1 | 0.01 | 0.36 | 0.72 | 1.08 | 1.44 | 1.8 | 3.6 | 7.2 | 10.8 | 14.4 | 18 | 36 |
| 2 | 0.02 | 0.25 | 0.51 | 0.76 | 1.02 | 1.27 | 2.55 | 5.09 | 7.64 | 10.18 | 12.73 | 25.46 |
| 3 | 0.03 | 0.21 | 0.42 | 0.62 | 0.83 | 1.04 | 2.08 | 4.16 | 6.24 | 8.31 | 10.39 | 20.78 |
| 4 | 0.04 | 0.18 | 0.36 | 0.54 | 0.72 | 0.9 | 1.8 | 3.6 | 5.4 | 7.2 | 9 | 18 |
| 5 | 0.05 | 0.16 | 0.32 | 0.48 | 0.64 | 0.8 | 1.61 | 3.22 | 4.83 | 6.44 | 8.05 | 16.1 |
| 10 | 0.1 | 0.11 | 0.23 | 0.34 | 0.46 | 0.57 | 1.14 | 2.28 | 3.42 | 4.55 | 5.69 | 11.38 |
| 20 | 0.2 | 0.08 | 0.16 | 0.24 | 0.32 | 0.4 | 0.8 | 1.61 | 2.41 | 3.22 | 4.02 | 8.05 |
| 30 | 0.3 | 0.07 | 0.13 | 0.2 | 0.26 | 0.33 | 0.66 | 1.31 | 1.97 | 2.63 | 3.29 | 6.57 |
| 40 | 0.4 | 0.06 | 0.11 | 0.17 | 0.23 | 0.28 | 0.57 | 1.14 | 1.71 | 2.28 | 2.85 | 5.69 |
| 50 | 0.5 | 0.05 | 0.1 | 0.15 | 0.2 | 0.25 | 0.51 | 1.02 | 1.53 | 2.04 | 2.55 | 5.09 |
| 100 | 1 | 0.04 | 0.07 | 0.11 | 0.14 | 0.18 | 0.36 | 0.72 | 1.08 | 1.44 | 1.8 | 3.6 |
| 200 | 2 | 0.03 | 0.05 | 0.08 | 0.1 | 0.13 | 0.25 | 0.51 | 0.76 | 1.02 | 1.27 | 2.55 |
| 300 | 3 | 0.02 | 0.04 | 0.06 | 0.08 | 0.1 | 0.21 | 0.42 | 0.62 | 0.83 | 1.04 | 2.08 |
| 400 | 4 | 0.02 | 0.04 | 0.05 | 0.07 | 0.09 | 0.18 | 0.36 | 0.54 | 0.72 | 0.9 | 1.8 |
| 500 | 5 | 0.02 | 0.03 | 0.05 | 0.06 | 0.08 | 0.16 | 0.32 | 0.48 | 0.64 | 0.8 | 1.61 |
| 1000 | 10 | 0.01 | 0.02 | 0.03 | 0.05 | 0.06 | 0.11 | 0.23 | 0.34 | 0.46 | 0.57 | 1.14 |
| 2000 | 20 | 0.01 | 0.02 | 0.02 | 0.03 | 0.04 | 0.08 | 0.16 | 0.24 | 0.32 | 0.4 | 0.8 |
| 3000 | 30 | 0.01 | 0.01 | 0.02 | 0.03 | 0.03 | 0.07 | 0.13 | 0.2 | 0.26 | 0.33 | 0.66 |
| 4000 | 40 | 0.01 | 0.01 | 0.02 | 0.02 | 0.03 | 0.06 | 0.11 | 0.17 | 0.23 | 0.28 | 0.57 |
| 7200 | 10800 | 14400 | 18000 | 36000 | 72000 | 108000 | 144000 | 180000 | 360000 | 720000 | ||
| 2 | 3 | 4 | 5 | 10 | 20 | 30 | 40 | 50 | 100 | 200 | ||
| 1 | 0.01 | 72 | 108 | 144 | 180 | 360 | 720 | 1080 | 1440 | 1800 | 3600 | 7200 |
| 2 | 0.02 | 50.91 | 76.37 | 101.82 | 127.28 | 254.56 | 509.12 | 763.68 | 1018.23 | 1272.79 | 2545.58 | 5091.17 |
| 3 | 0.03 | 41.57 | 62.35 | 83.14 | 103.92 | 207.85 | 415.69 | 623.54 | 831.38 | 1039.23 | 2078.46 | 4156.92 |
| 4 | 0.04 | 36 | 54 | 72 | 90 | 180 | 360 | 540 | 720 | 900 | 1800 | 3600 |
| 5 | 0.05 | 32.2 | 48.3 | 64.4 | 80.5 | 161 | 321.99 | 482.99 | 643.99 | 804.98 | 1609.97 | 3219.94 |
| 10 | 0.1 | 22.77 | 34.15 | 45.54 | 56.92 | 113.84 | 227.68 | 341.53 | 455.37 | 569.21 | 1138.42 | 2276.84 |
| 20 | 0.2 | 16.1 | 24.15 | 32.2 | 40.25 | 80.5 | 161 | 241.5 | 321.99 | 402.49 | 804.98 | 1609.97 |
| 30 | 0.3 | 13.15 | 19.72 | 26.29 | 32.86 | 65.73 | 131.45 | 197.18 | 262.91 | 328.63 | 657.27 | 1314.53 |
| 40 | 0.4 | 11.38 | 17.08 | 22.77 | 28.46 | 56.92 | 113.84 | 170.76 | 227.68 | 284.6 | 569.21 | 1138.42 |
| 50 | 0.5 | 10.18 | 15.27 | 20.36 | 25.46 | 50.91 | 101.82 | 152.74 | 203.65 | 254.56 | 509.12 | 1018.23 |
| 100 | 1 | 7.2 | 10.8 | 14.4 | 18 | 36 | 72 | 108 | 144 | 180 | 360 | 720 |
| 200 | 2 | 5.09 | 7.64 | 10.18 | 12.73 | 25.46 | 50.91 | 76.37 | 101.82 | 127.28 | 254.56 | 509.12 |
| 300 | 3 | 4.16 | 6.24 | 8.31 | 10.39 | 20.78 | 41.57 | 62.35 | 83.14 | 103.92 | 207.85 | 415.69 |
| 400 | 4 | 3.6 | 5.4 | 7.2 | 9 | 18 | 36 | 54 | 72 | 90 | 180 | 360 |
| 500 | 5 | 3.22 | 4.83 | 6.44 | 8.05 | 16.1 | 32.2 | 48.3 | 64.4 | 80.5 | 161 | 321.99 |
| 1000 | 10 | 2.28 | 3.42 | 4.55 | 5.69 | 11.38 | 22.77 | 34.15 | 45.54 | 56.92 | 113.84 | 227.68 |
| 2000 | 20 | 1.61 | 2.41 | 3.22 | 4.02 | 8.05 | 16.1 | 24.15 | 32.2 | 40.25 | 80.5 | 161 |
| 3000 | 30 | 1.31 | 1.97 | 2.63 | 3.29 | 6.57 | 13.15 | 19.72 | 26.29 | 32.86 | 65.73 | 131.45 |
| 4000 | 40 | 1.14 | 1.71 | 2.28 | 2.85 | 5.69 | 11.38 | 17.08 | 22.77 | 28.46 | 56.92 | 113.84 |
With a pressure drop of 2 bar, a water flow of 1 kg/s, the Kv value should be approximately 2.55.
