Engineering ToolBox > Copper Pipes - Insulation and Heat Loss
Heat loss to surrounding air from insulated copper tubes
The heat loss from an insulated copper pipe or tube to the surrounding air can be found in the table below. The heat loss is based on a temperature difference of 55oC (130oF) with an insulation thickness of 25 mm (1 inch) and a conductivity coefficient of k = 0.043 W/m oC (0.3 Btu in/ft2 hr oF).
Nominal bore Heat loss for fluid inside pipe
(mm) (inches) (W/m) (Btu/hr ft)
22 3/4 8 8
28 1 10 10
42 1 1/2 11.5 12
54 2 14.5 15
67 2 1/2 16 17
76 3 19 20
