Engineering ToolBox > Copper Tubes - ASTM B88M
Copper Water and Gas Tube according ASTM B 88M - metric units
Dimensions of copper tubes according ASTM B88M STANDARD SPECIFICATION FOR SEAMLESS COPPER WATER TUBE (METRIC) can be found in the table below:
Type A
Nominal Size
Outside Diameter
(mm)
Wall Thickness
(mm)
Tolerance +/-
Maximum Deviation at any Point
(mm)
Weight
(kg/m)
6 0.9 0.08 0.12
8 0.9 0.09 0.18
10 0.9 0.09 0.23
12 1.2 0.1 0.36
15 1.2 0.1 0.47
18 1.2 0.1 0.57
22 1.6 0.15 0.92
28 1.6 0.15 1.19
35 1.6 0.15 1.50
42 1.8 0.2 2.03
54 2.1 0.2 3.06
67 2.4 0.25 4.35
79 2.8 0.3 5.99
105 3.4 0.35 9.70
130 4.0 0.4 14.2
156 4.8 0.5 20.3
206 6.8 0.7 38.0
257 8.5 0.85 59.3
308 10.3 1 86.1
Type B
Nominal Size
Outside Diameter
(mm)
Wall Thickness
(mm)
Tolerance +/-
(mm)
Weight
(kg/m)
6 0.7 0.07 0.10
8 0.8 0.08 0.16
10 0.8 0.08 0.21
12 0.9 0.09 0.28
15 1.0 0.1 0.39
18 1.0 0.1 0.48
22 1.1 0.1 0.65
28 1.2 0.1 0.90
35 1.4 0.15 1.32
42 1.5 0.15 1.71
54 1.7 0.15 2.50
67 2.0 0.15 3.65
79 2.3 0.2 4.95
105 2.8 0.25 8.04
130 3.1 0.3 11.0
156 3.5 0.3 15.0
206 5.0 0.35 28.2
257 6.3 0.5 44.4
308 7.1 0.65 60.0
Type C
Nominal Size
Outside Diameter
(mm)
Wall Thickness
(mm)
Tolerance +/-
(mm)
Weight
(kg/m)
6 0.6 - 0.09
8 0.6 - 0.13
10 0.6 - 0.16
12 0.6 0.06 0.19
15 0.7 0.07 0.28
18 0.7 0.07 0.34
22 0.8 0.08 0.48
28 0.9 0.09 0.69
35 1.1 0.1 1.05
42 1.2 0.1 1.37
54 1.5 0.15 2.21
67 1.6 0.15 2.94
79 1.8 0.2 3.90
105 2.4 0.25 6.92
130 2.7 0.25 9.65
156 3.1 0.3 13.3
206 4.3 0.45 24.4
257 5.4 0.55 38.2
308 6.4 0.65 54.2
The B88M specification covers seamless copper water tube suitable for general plumbing, similar applications for the conveyance of fluids, and commonly used with solder, flared, or compression-type fittings. The type of copper water tube suitable for any particular application is determined by the internal or external fluid pressure, by the installation and service conditions, and by local requirements. Means of joining or bending are also factors that affect the selection of the type of tube to be used.
This specification is the metric companion of Specification B 88.
