Engineering ToolBox > Density Converter
Online density converter with the most common units
Density is an expression of the ratio mass per unit volume.
Density Converter
The calculator below can be used to convert between some common density units
Value (use period as decimal point)
kg/m3 g/cm3 oz/in3 oz/gal (imperial) oz/gal (US) lb/ft3 lb/in3 lb/yd3 lb/gal (imperial) lb/gal (US) ton/yd3
Density Converting Table
The table below can be used to convert between common density units:
Multiply by
Convert from Convert to
kg/m3 1 0.001 0.000578 0.1604 0.1335 0.0624 0.000036 1.6855 0.01 0.00835 0.00075
g/cm3 1000 1 0.578 160.4 133.52 62.43 0.036 1685.6 10.02 8.35 0.752
oz/in3 1730 1.73 1 277.4 231 108 0.0625 2916 17.34 14.44 1.302
oz/gal (imperial) 6.24 0.0062 0.0036 1 0.827 0.389 0.000225 10.51 0.0625 0.052 0.0047
oz/gal (US) 7.49 0.00749 0.0043 1.2 1 0.468 0.00027 12.62 0.075 0.0625 0.0056
lb/ft3 16.02 0.016 0.0093 2.57 2.14 1 0.000579 27 0.1605 0.134 0.0121
lb/in3 27680 27.68 16 4438.7 3696 1728 1 46656 277 231 20.82
lb/yd3 0.593 0.00059 0.00034 0.095 0.079 0.037 0.000021 1 0.00595 0.00495 0.00045
lb/gal (imperial) 99.78 0.0998 0.0577 16 13.32 6.23 0.0036 168.2 1 0.833 0.0751
lb/gal (US) 119.8 0.12 0.069 19.2 16 7.48 0.0043 201.97 1.2 1 0.09
ton/yd3 1328.9 1.329 0.768 213.1 177.4 82.96 0.048 2240 13.32 11.1 1
