Engineering ToolBox > Drag Coefficient
The drag coefficient is used to express the drag of an object in moving fluid
Any object moving through a fluid will experience a drag - the net force in direction of flow due to the pressure and shear stress forces on the surface of the object.
The drag force can be expressed as:
Fd = cd 1/2 ρ v2 A (1)
Fd = drag force (N)
cd = drag coefficient
ρ = density of fluid
v = flow velocity
A = characteristic frontal area of the body
The drag coefficient is a function of several parameters as shape of the body, Reynolds Number for the flow, Froude number, Mach Number and Roughness of the Surface.
The characteristic frontal area - A - depends on the body.
Most of the information about the drag on objects is a result of experiments. Drag coefficients for some common bodies:
Type of Object Drag Coefficient
- cd -
Frontal Area
- A -
(ft2)
Old Car like a T-ford 0,7 - 0,9 frontal area
Modern Car like Toyota Prius 0,26 frontal area
Common Car like Open Vectra (class C) 0.29 frontal area
Passenger Train 1.8 frontal area
Bike Upright Commuter 1.1 5.5
Bike racing 0.88 3.9
Tractor Trailed Truck 0.96 frontal area
Dolphin 0.0036 wetted area
Bird 0.4 frontal area
Solid Hemisphere 0.42 π / 4 d2
Solid Hemisphere flow normal to flat side 1.17 π / 4 d2
Thin Disk 1.1 π / 4 d2
Cube 0.8 s2
Streamline body 0.04 π / 4 d2
Squared flat plate at 90 deg 1.17
Long flat plate at 90 deg 1.98
Hollow semi-sphere opposite stream 1.42
Hollow semi-sphere facing stream 0.38
Hollow semi-cylinder opposite stream 1.20
Wires and cables 1.0 - 1.3
Laminar flat plate (Re=106) 0.001
Turbulent flat plate (Re=106) 0.005
Subsonic Transport Aircraft 0.012
Supersonic Fighter, M=2.5 0.016
Person (upright position) 1.0 - 1.3
Ski jumper 1.2 - 1.3
