Engineering ToolBox > Paper Drafting Sizes - ISO 216 series A, B and C
The ISO 216 A, B and C drawing series - dimensions of regular, oversized and envelope sheets
ISO 216 "Writing paper and certain classes of printed matter; Trimmed sizes; A and B series" specifies international standard (ISO) paper sizes, used in most countries in the world today with three series of paper sizes: A, B and C. Series C is primarily used for envelopes.
ISO A Series
The ISO A series of sheet sizes is based on a constant width to length ratio of 1:√2 (rounded to the nearest millimetre). The A0 size is defined as having an area of one square meter (1 m2). Paper weights is expressed in grams per square meter.
Each smaller sheet size is exactly half the area of the previous size.
ISO A Series Size
(mm) (inches)
A0 841 x 1189 33.11 x 46.81
A1 594 x 841 23.39 x 33.1
A2 420 x 594 16.54 x 23.29
A3 297 x 420 11.69 x 16.54
A4 210 x 297 8.27 x 11.69
A5 148 x 210 5.83 x 8.27
ISO 216 does not define sizes larger than A0 or B0. With the German standard DIN 476 "Trimmed sizes of paper" the sizes can be expanded by using a factor in front of the size:
Oversized ISO A Sheets
Oversized sheets are used when it is desirable to give extra protection to the drawing sheets by providing a binding or trimming margin.
ISO A Series Size
(mm)
RA0 860 x 1220
RA1 610 x 860
RA2 430 x 610
RA3 305 x 430
RA4 215 x 305
RA5 153 x 215
ISO B Series
The ISO B series are geometric means between the A series and defined to satisfy the requirements of sizes between the A series sizes. For example, B1 is a geometric mean between A1 and A0.
ISO B Series Size
(mm) (inches)
B0 1000 x 1414 39.37 x 55.67
B1 707 x 1000 27.83 x 39.37
B2 500 x 707 19.68 x 27.83
B3 353 x 500 13.90 x 19.68
B4 250 x 353 9.84 x 13.90
B5 176 x 250 6.93 x 9.84
ISO C Series - Envelopes
Series C is primarily used for envelopes. The C series formats are geometric means between the B series format with the same number and the A series format with the same number - C2 is the geometric mean between B2 and A2.
ISO C Series
Envelopes
Size
(mm) (inches)
C0 917 x 1297 36.00 x 51.20
C1 648 x 917 25.60 x 36.00
C2 458 x 648 18.00 x 25.60
C3 324 x 458 12.80 x 18.00
C4 229 x 324 9.00 x 12.80
C5 162 x 229 6.40 x 9.0
An A4 page will fit into a C4 envelope, A5 will fit into a C5 envelope and so on.
