Engineering ToolBox > Dynamic, Absolute and Kinematic Viscosity
The viscosity of a fluid is an important property in the analysis of liquid behavior and fluid motion near solid boundaries.
The viscosity is the fluid resistance to shear or flow and is a measure of the adhesive/cohesive or frictional fluid property. The resistance is caused by intermolecular friction exerted when layers of fluids attempt to slide by one another.
The knowledge of viscosity is needed for proper design of required temperatures for storage, pumping or injection of fluids.
Common used units for viscosity are
1centistokes greater than 50
There are two related measures of fluid viscosity - known as dynamic (or absolute) and kinematic viscosity.
is the tangential force per unit area required to move one horizontal plane with respect to the other at unit velocity when maintained a unit distance apart by the fluid.
The shearing stress between the layers of non turbulent fluid moving in straight parallel lines can be defined for a Newtonian fluid as:
The dynamic or absolute viscosity can be expressed like
τ = μ dc/dy (1)
τ = shearing stress
μ = dynamic viscosity
Equation (1) is known as the Newtons Law of Friction.
In the SI system the dynamic viscosity units are N s/m2, Pa s or kg/m s where
The dynamic viscosity is also often expressed in the metric CGS (centimeter-gram-second) system as g/cm.s, dyne.s/cm2 or poise (p) where
For practical use the Poise is to large and it's usual divided by 100 into the smaller unit called the centiPoise (cP) where
Water at 68.4oF (20.2oC) has an absolute viscosity of one - 1 - centiPoise.
is the ratio of absolute or dynamic viscosity to density - a quantity in which no force is involved. Kinematic viscosity can be obtained by dividing the absolute viscosity of a fluid with its mass density as
ν = μ / ρ (2)
ν = kinematic viscosity
μ = absolute or dynamic viscosity
ρ = density
In the SI-system the theoretical unit is m2/s or commonly used Stoke (St) where
Since the Stoke is an unpractical large unit, it is usual divided by 100 to give the unit called Centistokes (cSt) where
Since the specific gravity of water at 68.4oF (20.2oC) is almost one - 1, the kinematic viscosity of water at 68.4oF is for all practical purposes 1.0 cSt.
The viscosity of a fluid is highly temperature dependent and for either dynamic or kinematic viscosity to be meaningful, the reference temperature must be quoted. In ISO 8217 the reference temperature for a residual fluid is 100oC. For a distillate fluid the reference temperature is 40oC.
Saybolt Universal Seconds (or SUS) is used to measure viscosity. The efflux time is Saybolt Universal Seconds (SUS) required for 60 milliliters of a petroleum product to flow through the calibrated orifice of a Saybolt Universal viscometer, under carefully controlled temperature and as prescribed by test method ASTM D 88. This method has largely been replaced by the kinematic viscosity method. Saybolt Universal Seconds is also called the SSU number (Seconds Saybolt Universal) or SSF number (Saybolt Seconds Furol).
Kinematic viscosity versus dynamic or absolute viscosity can be expressed as
ν = 4.63 μ / SG (3)
ν = kinematic vicosity (SSU)
μ = dynamic or absolute viscosity (cP)
Degree Engler is used in Great Britain as a scale to measure kinematic viscosity. Unlike the Saybolt and Redwood scales, the Engler scale is based on comparing a flow of the substance being tested to the flow of another substance - water. Viscosity in Engler degrees is the ratio of the time of a flow of 200 cubic centimetres of the fluid whose viscosity is being measured - to the time of flow of 200 cubic centimeters of water at the same temperature (usually 20oC but sometimes 50oC or 100oC) in a standardized Engler viscosity meter.
Fluids for which the shearing stress is linearly related to the rate of shearing strain are designated as Newtonian Fluids.
Newtonian materials are referred to as true liquids since their viscosity or consistency is not affected by shear such as agitation or pumping at a constant temperature. Fortunately most common fluids, both liquids and gases, are Newtonian. Water and oils are examples of Newtonian liquids.
Shear Thinning Fluids or Thixotropic Fluids reduce their viscosity as agitation or pressure is increased at a constant temperature. Ketchup and mayonnaise are examples of thixotropic materials. They appear thick or viscous but are possible to pump quite easily.
Shear Thickening Fluids or Dilatant Fluids increase their viscosity with agitation. Some of these liquids can become almost solid within a pump or pipe line. With agitation, cream becomes butter and Candy compounds, clay slurries and similar heavily filled liquids do the same thing.
Bingham Plastic Fluids have a yield value which must be exceeded before it will start to flow like a fluid. From that point the viscosity will decrease with increase of agitation. Toothpaste, mayonnaise and tomato catsup are examples of such products.
Kinematic viscosity of air at 1 bar and 40oC is 16.97 cSt (16.97 10-6 m2/s).
The density of air may be estimated by the Ideal Gas Law:
ρ = 105 / (287 × 313) = 1.113 kg/m3
The absolute viscosity can be expressed as
μ = 1.113 × 16.97 10-6
= 1.88 10-5 kg/ms (Ns/m2) (P)
| centiStokes (cSt) | Saybolt Second Universal (SSU, SUS) | Typical liquid |
| 1 | 31 | Water (20oC) |
| 4.3 | 40 | Milk SAE 20 Crankcase Oil SAE 75 Gear Oil |
| 15.7 | 80 | No. 4 fuel oil |
| 20.6 | 100 | Cream |
| 43.2 | 200 | Vegetable oil |
| 110 | 500 | SAE 30 Crankcase Oil SAE 85 Gear Oil |
| 220 | 1000 | Tomato Juice SAE 50 Crankcase Oil SAE 90 Gear Oil |
| 440 | 2000 | SAE 140 Gear Oil |
| 1100 | 5000 | Glycerine (20oC) SAE 250 Gear Oil |
| 2200 | 10,000 | Honey |
| 6250 | 28,000 | Mayonnaise |
| 19,000 | 86,000 | Sour cream |
Kinematic viscosity can be converted from SSU to Centistokes like
νCentistokes = 0.226 νSSU - 195 / νSSU
νSSU < 100
νCentistokes = 0.220 νSSU - 135 / νSSU
νSSU > 100
