Engineering ToolBox > Online Absolute or Dynamic Viscosity Converter
Convert between dynamic or absolute viscosity units - Poiseuille, Poise, centPoise and more
Dynamic (absolute) Viscosity Units Online Calculator
The calculator below can be used to convert between common absolute or dynamic viscosity units:
Value (use period as decimal point)
Poiseuille (Pa s) Poise (dyne s/cm2, g/cm s) centiPoise kg/m h kgf s/m2 lbf s/inch2 lbf s/ft2 lbf h/ft2 lb/ft s lb/ft h
A Dynamic or Absolute Viscosity Units Converting Table
The table below can be used to convert between common dynamic or absolute viscosity units.
Multiply by
Convert from Convert to
Poiseuille
(Pa s)
Poise
(dyne s/cm2)
(g/cm s)
Poiseuille
(Pa s)
1 10 103 3.63 103 0.102
Poise
(dyne s/cm2)
(g/cm s)
0.1 1 100 360 0.0102
centiPoise 0.001 0.01 1 3.6 0.00012
kg/m h 2.78 10-4 0.00278 0.0278 1 2.83 10-5
kgf s/m2 9.81 98.1 9.81 103 3.53 104 1
lbf s/inch2 6.89 103 6.89 104 6.89 106 2.48 107 703
lbf s/ft2 47.9 479 4.79 104 1.72 105 0.0488
lbf h/ft2 1.72 105 1.72 106 1.72 108 6.21 108 1.76 104
lb/ft s 1.49 14.9 1.49 103 5.36 103 0.152
lb/ft h 4.13 10-4 0.00413 0.413 1.49 4.22 10-5
Multiply by
Poiseuille
(Pa s)
1.45 10-4 0.0209 5.8 10-6 0.672 2.42 103
Poise
(dyne s/cm2
g/cm s)
1.45 10-5 0.00209 5.8 10-7 0.0672 242
centiPoise 1.45 10-7 2.09 10-5 5.8 10-9 0.000672 2.42
kg/m h 4.03 10-8 5.8 10-6 1.61 10-9 0.000187 0.672
kgf s/m2 0.00142 20.5 5.69 10-5 6.59 2.37 104
lbf s/inch2 1 144 0.04 4.63 103 1.67 107
lbf s/ft2 0.00694 1 0.000278 32.2 1.16 105
lbf h/ft2 25 3.6 103 1 1.16 105 4.17 108
lb/ft s 0.000216 0.0311 8.63 10-6 1 3.6 103
lb/ft h 6 10-8 1.16 105 2.4 10-9 0.000278 1
Common Dynamic or Absolute Viscosity Units
