Engineering ToolBox > Power and Horsepower in Electrical Motors
Electrical power is rated in Horsepower or Watts.
Electrical power is in general rated in Watts or Horsepower. A horsepower is a unit of power equal to 746 watts or 33,000 lb.ft per minute (or 550 lb.ft per second).
A watt is a unit of measure equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, its common to rate motor power is in either horsepower or watts.
Power in Watts
Electric power of a motor can be expressed as:
Pw = ηm U I (1)
Pw = power (W, watt)
ηm = motor efficiency
U = voltage (V)
I = current (A, amps)
Power in Horsepower
Horse power of a motor can be expressed as:
Php = Pw / 746 (2)
or
Php = ηm U I / 746 (2b)
Php = horsepower (hp)
Example - The Horsepower of an Electrical Motor
The horsehorse power of an 230 V electrical motor with 85% efficiency pulling 10 amps can be calculated as:
Php = 0.85 (230 V) (10 amps) / 746
    = 2,62 hp
