Engineering ToolBox > Energy and Hydraulic Grade Line
The hydraulic grade and the energy line are graphical forms of the Bernoulli equation
The Bernoulli Equation
For steady, inviscid, incompressible flow the total energy remains constant along a stream line as expressed through the Bernoulli Equation:
p + 1/2 ρ v2 + γ h = constant along a streamline (1)
p = static pressure (relative to the moving fluid)
ρ = density
γ = specific weight
v = flow velocity
g = acceleration of gravity
h = elevation height
Each term of this equation has the dimension force per unit area - psi, lb/ft2 or N/m2.
energy line hydraulic grade line
The Head
By dividing each term with the specific weight - γ = ρ g - (1) can be transformed to express the "head":
p / γ + v2 / 2 g + h = constant along a streamline = H (2)
H = the total head
Each term of this equation has the dimension length - ft, m.
The Total Head
(2) states that the sum of pressure head - p / γ -, velocity head - v2 / 2 g - and elevation head - h - is constant along the stream line. This constant can be called the total head - H -.
The total head in a flow can be measured by the stagnation pressure using a pitot tube.
The Piezometric Head
The sum of pressure head - p / γ - and elevation head - h - is called the piezometric head. The piezometric head in a flow can be measured through an flat opening parallel to the flow.
The Energy Line
The Energy Line is a line that represent the total head available to the fluid and can be expressed as:
EL = H = p / γ + v2 / 2 g + h = constant along a streamline (3)
EL = Energy Line
For a fluid flow without any losses due to friction (major losses) or components (minor losses) the energy line would be at a constant level. In the practical world the energy line decreases along the flow due to the losses.
A turbine in the flow will reduce the energy line and a pump or fan will increase the energy line.
The Hydraulic Grade Line
The Hydraulic Grade Line is a line that represent the total head available to the fluid minus the velocity head and can be expressed as:
HGL = p / γ + h (4)
HGL = Hydraulic Grade Line
The hydraulic grade line lies one velocity head below the the energy line.
