Engineering ToolBox > Equation of Continuity
The Equation of Continuity is a statement of mass conservation
The Law of Conservation of Mass states that mass can be neither created or destroyed. Using the Mass Conservation Law on a steady flow process - flow where the flow rate don't change over time - through a control volume where the stored mass in the control volume don't change - implements that inflow equals outflow.
This statement is called the Equation of Continuity.
equation of continuity
Common application where the Equation of Continuity can be used are pipes, tubes and ducts with flowing fluids and gases, rivers, overall processes as power plants, diaries, logistics in general, roads, computer networks and semiconductor technology and more.
The Equation of Continuity and can be expressed as:
m = ρi1 vi1 Ai1 + ρi2 vi2 Ai2 +..+ ρin vin Aim
    = ρo1 vo1 Ao1 + ρo2 vo2 Ao2 +..+ ρom vom Aom (1)
m = mass flow rate (kg/s)
ρ = density (kg/m3)
v = speed (m/s)
A = area (m2)
With uniform density equation (1) can be modified to
q = vi1 Ai1 + vi2 Ai2 +..+ vin Aim
    = vo1 Ao1 + vo2 Ao2 +..+ vom Aom (2)
q = flow rate (m3/s)
ρi1 = ρi2 = . . = ρin = ρo1 = ρo2 = . .= ρom
Example - Equation of Continuity
10 m3/h of water flows through a pipe of 100 mm inside diameter. The pipe is reduced to an inside dimension of 80 mm.
Using equation (2) the velocity in the 100 mm pipe can be calculated as
(10 m3/h)(1 / 3600 h/s) = v100 (3.14 x 0.1 (m) x 0.1 (m) / 4)
or
v100 = (10 m3/h)(1 / 3600 h/s) / (3.14 x 0.1 (m) x 0.1 (m) / 4)
    = 0.35 m/s
Using equation (2) the velocity in the 80 mm pipe can be calculated
(10 m3/h)(1 / 3600 h/s) = v80 (3.14 x 0.08 (m) x 0.08 (m) / 4)
or
v100 = (10 m3/h)(1 / 3600 h/s) / (3.14 x 0.08 (m) x 0.08 (m) / 4)
= 0.55 m/s
