Engineering ToolBox > Fan Affinity Laws
Turbo machines affinity laws are used to calculate volume capacity, head or power consumption, when speed - rpm, or wheel diameters are changed for centrifugal fans
The Affinity Laws of centrifugal pumps or fans can be used to express the influence on volume capacity, head (pressure) or power consumption of a pump or fan due to
  1. change in speed of wheel - revolutions per minute (rpm)
  2. geometrically similarity - change in impeller diameter
Note that the affinity laws for pumps are not identical with fans.
Fan Affinity Laws
Volume Capacity
The volume capacity of a centrifugal fan can be expressed like
q1 / q2 = (n1 / n2)(d1 / d2)3 (1)
q = volume flow capacity (m3/s, gpm, cfm, ..)
n = wheel velocity - revolution per minute - (rpm)
d = wheel diameter
Head or Pressure
The head or pressure of a centrifugal fan can be expressed like
dp1 / dp2 = (n1 / n2)2 (d1 / d2)2 (2)
dp = head or pressure  (m, ft, Pa, psi, ..)
Power
The power consumption of a centrifugal fan can be expressed as
P1 / P2 = (n1 / n2)3 (d1 / d2)5 (3)
P = power (W, bhp, ..)
Changing the Wheel Velocity
If the wheel diameter is constant - change in fan wheel velocity can simplify the affinity laws to
Volume Capacity
q1 / q2 = (n1 / n2) (1a)
Head or Pressure
dp1 / dp2 = (n1 / n2)2  (2a)
Power
P1 / P2 = (n1 / n2)3  (3a)
fan affinity laws velocity diagram
Note! If the speed of a fan is increased with 10%
If we want to increase the volume flow capacity of an existing system with 10% we have to increase the power supply with 33%. In  this situation the electrical motor and power supply may need to be upgraded.
Fan Affinity Laws Calculator - Changing Wheel Velocity
Replace the default values with the actual values. The calculator is generic and can be used with all common units as long as the use is consistent.
q1 - volume capacity - (m3/s, gpm, cfm, ..)
dp1 - head or pressure (m, ft, Pa, psi, ..)
P1 - power (W, bhp)
n1 - initial wheel velocity (rpm)
n2 - final wheel velocity (rpm)
Changing the Impeller Diameter
If wheel velocity is constant a change in impeller diameter can simplify the affinity laws to
Volume Capacity
q1 / q2 = (d1 / d2)3 (1b)
Head or Pressure
dp1 / dp2 = (d1 / d2)2 (2b)
Power
P1 / P2 = (d1 / d2)5 (3b)
fan affinity laws diameter diagram
Fan Affinity Laws Calculator - Changing Wheel Diameter
P1 - power (W, bhp)
d1 - initial wheel diameter (m, in, ft  ...)
d2 - final wheel diameter (m, in, ft ..)
