Engineering ToolBox > Types of Fans
It is common to classify fans in
The pressure head of different types of fans with equal periphery speed of the wheel are compared in the capacity diagram below:
Centrifugal fans with forwarded blades are suited for application with higher air flow volumes and pressures. Axial propeller fans are more suited for applications with lower volumes and pressures.
In an axial fan the air flows in parallel to the shaft. It is common to classify axial fans upon their wheel like:
The pressure head developed for single stage is up to 300 N/m2. Axial fans are suited for relatively large volumes compared to pressure.
In a centrifugal fan the air flows is in a radial direction relative to the shaft. Centrifugal fans can be classified by their wheel like:
Types of blades used in centrifugal fans are
The different blades can be characterized as shown in the capacity diagram below:
In a mixed flow fan the air flows in both axial and radial direction relative to the shaft. Mixed flow fans develops higher pressures than axial fans.
In a cross flow fan the air flows in an inward direction and then in an outward radial direction.
