Engineering ToolBox > Fans and Capacity Control
It is common to present the pressure head of fans as a function of air volume in a capacity diagram:
The red lines gives the pressure head as a function of the air volume. One line for each different speed of the fan. The black lines marked "l" are the duct curves (throttle lines). The blue lines are the power consumption of the fan.
Modulating the fan capacity can be done by
The capacity can be controlled by modulating the capacity as shown in the capacity diagram below:
The speed of the fan can be changed by a using a frequency controller or changing the configuration of the fan and/or the motor disc drive.
The belt gearing can be expressed as:
dfan nfan = dbeltdisc nbeltdisc (1)
d = diameter
n = speed
With a frequency controller the fan can be modulated from the control system.
If an inlet vane damper is properly installed, it provides an inlet swirl in the direction of the fan rotation. This will reduce the power consumption of the fan.
The power consumption will not be reduced as much as with speed modulation.
Adjusting blades is possible on some axial and propeller fans.
This will reduce the fans power consumption but not as much as modulating the speed.
Throttling the fan with a discharge damper will reduce the air flow volume, but the systems pressure loss will be increased.
The power consumption will still be high, the fan efficiency low, and the method should in general be avoided.
