Engineering ToolBox > Fans - Efficiency and Power Consumption
The ideal power consumption of a fan (without losses) can be expressed as
Pi = dp q (1)
Pi = ideal power consumption (W)
dp = total pressure increase in the fan (Pa)
q = air volume flow delivered by the fan (m3/s)
The ideal power consumptions for fans at different air volumes and pressure increases are expressed in the chart below:
Note! For detailed engineering the manufacturing specifications of each fan must be used.
The fan efficiency is the ratio between power transferred to the airflow and the power used by the fan. The fan efficiency is in general independent of the air density and can be expressed as:
μf = dp q / P (2)
μf = fan efficiency (values between 0 - 1)
dp = total pressure (Pa)
q = air volume delivered by the fan (m3/s)
P = power used by the fan (W, Nm/s)
The power used by the fan can be expressed as:
P = dp q / μf (3)
The power used by the fan can also be expressed as:
P = dp q / (μf μb μm) (4)
μb = belt efficiency
μm = motor efficiency
Typical motor and belt efficiencies:
Fan energy use can also be expressed as
Pcfm = 0.1175 qcfm dpin / (μf μb μm) (4b)
Pcfm = power consumption (W)
qcfm = volume flow (cfm)
dpin = pressure increase (in. WG)
The installation of a fan will influence on the overall system efficiency
dpsy = xsy pd (5)
dpsy = installation loss (Pa)
xsy = installation loss coefficient
pd = dynamic pressure in the nominal intake and outlet of the fan (Pa)
Near all of the energy lost in a fan will heat up the air flow and the temperature increase can be expressed like
dt = dp / 1000 (6)
dt = temperature increase (K)
dp = increased pressure head (Pa)
