Engineering ToolBox > Flanges and Bolt Dimensions - 150 lb to 2500 lb - ASME/ANSI B16.5
Flange dimensions are determined by pipe size and pressure class required for the application. Most of these dimensions have been standardized and published as ASME, MSS, API or other standardization organization specifications.
ASME/ANSI B16.5 provides dimensions and tolerances for flanges in pipe sizes from 1/2" through 24" and in pressure classes from 150 lb through 2500 lb.
| Nominal Pipe Size NPS (inches) | 150 psi | |||
| Diameter of Flange (inches) | No. of Bolts | Diameter of Bolts (inches) | Bolt Circle (inches) | |
| 1/4 | 3-3/8 | 4 | 1/2 | 2-1/4 |
| 1/2 | 3-1/2 | 4 | 1/2 | 2-3/8 |
| 3/4 | 3-7/8 | 4 | 1/2 | 2-3/4 |
| 1 | 4-1/4 | 4 | 1/2 | 3-1/8 |
| 1-1/4 | 4-5/8 | 4 | 1/2 | 3-1/2 |
| 1-1/2 | 5 | 4 | 1/2 | 3-7/8 |
| 2 | 6 | 4 | 5/8 | 4-3/4 |
| 2-1/2 | 7 | 4 | 5/8 | 5-1/2 |
| 3 | 7-1/2 | 4 | 5/8 | 6 |
| 3-1/2 | 8-1/2 | 8 | 5/8 | 7 |
| 4 | 9 | 8 | 5/8 | 7-1/2 |
| 5 | 10 | 8 | 3/4 | 8-1/2 |
| 6 | 11 | 8 | 3/4 | 9-1/2 |
| 8 | 13-1/2 | 8 | 3/4 | 11-3/4 |
| 10 | 16 | 12 | 7/8 | 14-1/4 |
| 12 | 19 | 12 | 7/8 | 17 |
| 14 | 21 | 12 | 1 | 18-3/4 |
| 16 | 23-1/2 | 16 | 1 | 21-1/4 |
| 18 | 25 | 16 | 1-1/8 | 22-3/4 |
| 20 | 27-1/2 | 20 | 1-1/8 | 25 |
| 24 | 32 | 20 | 1-1/4 | 29-1/2 |
| Nominal Pipe Size NPS (inches) | 300 psi | |||
| 1/2 | 3-3/4 | 4 | 1/2 | 2-5/8 |
| 3/4 | 4-5/8 | 4 | 5/8 | 3-1/4 |
| 1 | 4-7/8 | 4 | 5/8 | 3-1/2 |
| 1-1/4 | 5-1/4 | 4 | 5/8 | 3-7/8 |
| 1-1/2 | 6-1/8 | 4 | 3/4 | 4-1/2 |
| 2 | 6-1/2 | 8 | 5/8 | 5 |
| 2-1/2 | 7-1/2 | 8 | 3/4 | 5-7/8 |
| 3 | 8-1/4 | 8 | 3/4 | 6-5/8 |
| 3-1/2 | 9 | 8 | 3/4 | 7-1/4 |
| 4 | 10 | 8 | 3/4 | 7-7/8 |
| 5 | 11 | 8 | 3/4 | 9-1/4 |
| 6 | 12-1/2 | 12 | 3/4 | 10-5/8 |
| 8 | 15 | 12 | 7/8 | 13 |
| 10 | 17-1/2 | 16 | 1 | 15-1/4 |
| 12 | 20-1/2 | 16 | 1-1/8 | 17-3/4 |
| 14 | 23 | 20 | 1-1/8 | 20-1/4 |
| 16 | 25-1/2 | 20 | 1-1/4 | 22-1/2 |
| 18 | 28 | 24 | 1-1/4 | 24-3/4 |
| 20 | 30-1/2 | 24 | 1-1/4 | 27 |
| 24 | 36 | 24 | 1-1/2 | 32 |
| Nominal Pipe Size NPS (inches) | 400 psi | |||
| 3-1/2 | 9 | 8 | 7/8 | 7-1/4 |
| 4 | 10 | 8 | 7/8 | 7-7/8 |
| 5 | 11 | 8 | 7/8 | 9-1/4 |
| 6 | 12-1/2 | 12 | 7/8 | 10-5/8 |
| 8 | 15 | 12 | 1 | 13 |
| 10 | 17-1/2 | 16 | 1-1/8 | 15-1/4 |
| 12 | 20-1/2 | 16 | 1-1/4 | 17-3/4 |
| 14 | 23 | 20 | 1-1/4 | 20-1/4 |
| 16 | 25-1/2 | 20 | 1-3/8 | 22-1/2 |
| 18 | 28 | 24 | 1-3/8 | 24-3/4 |
| 20 | 30-1/2 | 24 | 1-1/2 | 27 |
| 24 | 36 | 24 | 1-3/4 | 32 |
| Nominal Pipe Size NPS (inches) | 600 psi | |||
| 4 | 10-3/4 | 8 | 7/8 | 8-1/2 |
| 5 | 13 | 8 | 1 | 10-1/2 |
| 6 | 14 | 12 | 1 | 11-1/2 |
| 8 | 16-1/2 | 12 | 1-1/8 | 13-3/4 |
| 10 | 20 | 16 | 1-1/4 | 17 |
| 12 | 22 | 20 | 1-1/4 | 19-1/4 |
| 14 | 23-3/4 | 20 | 1-3/8 | 20-3/4 |
| 16 | 27 | 20 | 1-1/2 | 23-3/4 |
| 18 | 29-1/4 | 20 | 1-5/8 | 25-3/4 |
| 20 | 32 | 24 | 1-5/8 | 28-1/2 |
| 24 | 37 | 24 | 1-7/8 | 33 |
| Nominal Pipe Size NPS (inches) | 900 psi | |||
| 1/2 | 4-3/4 | 4 | 3/4 | 3-1/4 |
| 3/4 | 5-1/8 | 4 | 3/4 | 3-1/2 |
| 1 | 5-7/8 | 4 | 7/8 | 4 |
| 1-1/4 | 6-1/4 | 4 | 7/8 | 4-3/8 |
| 1-1/2 | 7 | 4 | 1 | 4-7/8 |
| 2 | 8-1/2 | 8 | 7/8 | 6-1/2 |
| 2-1/2 | 9-5/8 | 8 | 1 | 7-1/2 |
| 3 | 9-1/2 | 8 | 7/8 | 7-1/2 |
| 4 | 11-1/2 | 8 | 1-1/8 | 9-1/4 |
| 5 | 13-3/4 | 8 | 1-1/4 | 11 |
| 6 | 15 | 12 | 1-1/8 | 12-1/2 |
| 8 | 18-1/2 | 12 | 1-3/8 | 15-1/2 |
| 10 | 21-1/2 | 16 | 1-3/8 | 18-1/2 |
| 12 | 24 | 20 | 1-3/8 | 21 |
| 14 | 25-1/4 | 20 | 1-1/2 | 22 |
| 16 | 27-3/4 | 20 | 1-5/8 | 24-1/2 |
| 18 | 31 | 20 | 1-7/8 | 27 |
| 20 | 33-3/4 | 20 | 2 | 29-1/2 |
| 24 | 41 | 20 | 2-1/2 | 35-1/2 |
| Nominal Pipe Size NPS (inches) | 1500 psi | |||
| 3 | 10-1/2 | 8 | 1-1/8 | 8 |
| 4 | 12-1/4 | 8 | 1-1/4 | 9-1/2 |
| 5 | 14-3/4 | 8 | 1-1/2 | 11-1/2 |
| 6 | 15-1/2 | 12 | 1-3/8 | 12-1/2 |
| 8 | 19 | 12 | 1-5/8 | 15-1/2 |
| 10 | 23 | 12 | 1-7/8 | 19 |
| 12 | 26-1/2 | 16 | 2 | 22-1/2 |
| 14 | 29-1/2 | 16 | 2-1/4 | 25 |
| 16 | 32-1/2 | 16 | 2-1/2 | 27-3/4 |
| 18 | 36 | 16 | 2-3/4 | 30-1/2 |
| 20 | 38-3/4 | 16 | 3 | 32-3/4 |
| 24 | 46 | 16 | 3-1/2 | 39 |
| Nominal Pipe Size NPS (inches) | 2500 psi | |||
| 1/2 | 5-1/4 | 4 | 3/4 | 3-1/2 |
| 3/4 | 5-1/2 | 4 | 3/4 | 3-3/4 |
| 1 | 6-1/4 | 4 | 7/8 | 4-1/4 |
| 1-1/4 | 7-1/4 | 4 | 1 | 5-1/8 |
| 1-1/2 | 8 | 4 | 1-1/8 | 5-3/4 |
| 2 | 9-1/4 | 8 | 1 | 6-3/4 |
| 2-1/2 | 10-1/2 | 8 | 1-1/8 | 7-3/4 |
| 3 | 12 | 8 | 1-1/4 | 9 |
| 4 | 14 | 8 | 1-1/2 | 10-3/4 |
| 5 | 16-1/2 | 8 | 1-3/4 | 12-3/4 |
| 6 | 19 | 8 | 2 | 14-1/2 |
| 8 | 21-3/4 | 12 | 2 | 17-1/4 |
| 10 | 26-1/2 | 12 | 2-1/2 | 21-1/4 |
| 12 | 30 | 12 | 2-3/4 | 24-3/8 |
