Engineering ToolBox > Flow Coefficient Cv and Flow Factor Kv
Comparing the flow coefficient Cv with the flow factor Kv
The flow coefficient - Cv - and the flow factor - Kv - are commonly used to specify the capacit of control valves.
The Flow Coefficient - Cv
It is often convenient to express the capacities and flow characteristics of control valves in terms of the
The flow coefficient - Cv - is based on the imperial units system and is defined as:
The flow coefficient is commonly used in the U.S.
The Flow Factor - Kv
The metric equivalent of the flow coefficient - Cv - is based on the SI-system and is called the
The flow factor - Kv - is defined as
The flow factor is commonly used outside U.S.
Converting between Flow Coefficient Cv and Flow Factor Kv
The connection between Cv and Kv can be expressed as:
