Engineering ToolBox > Flowmeters and Turndown Ratio
Turndown ratio is often used to compare the span - the range - of flow measurement devices.
Turndown ratio can be expressed as:
TR = qmax / qmin (1)
TR = Turndown Ratio
qmax = maximum flow
qmin = minimum flow
Maximum and minimum flow is stated within a specified accuracy and repeatability for the device.
The turndown ratio - TR - for an orifice meter with maximum flow of 12 kg/s and a minimum flow of 3 kg/s can be calculated as:
TR = (12 kg/s) / (3 kg/s) = 4 - normally expressed as turndown ratio of 4:1
This is a typical turndown ratio for a orifice plate. In general a orifice plates has turndown ratio between 3:1 and 5:1.
In a flow meter based on the orifice or venturi principle, the differential pressure upstream and downstream of an obstruction in the flow is used to indicate the flow. According the Bernoulli Equation the differential pressure increases with the square of flow velocity. A large turndown ratio will cramp the measurement signal at low flow rate.
