Engineering ToolBox > Flowmeters and Accuracy
Accuracy indicates how close the measured value is to the accepted or true value.
The accuracy of flowmeters can be stated as:
Accuracy in percent of full span can be expressed as:
a% = a 100% / s (1)
a% = relative accuracy (%)
a = +/- absolute accuracy
s = full scale of the flowmeter
If the absolute accuracy is +/- 10 kg/h - the relative accuracy at full scale 1000 kg/h can be calculated as:
a% = (+/- 10 kg/h) 100% / (1000 kg/h)
= +/- 1%
The relative accuracy at full scale 100 kg/h can be calculated as:
a% = (+/- 10 kg/h) 100% / (100 kg/h)
= +/- 10%
Accuracy in percent of rate can be expressed as:
a% = a 100% / q (2)
q = flow rate
If the relative accuracy is +/- 1% of rate - the absolute accuracy at rate 1000 kg/h can be calculated as:
a = (+/- 1%) (1000 kg/h)
= +/- 10 kg/h
The absolute accuracy at rate 100 kg/h can be calculated as:
a = (+/- 1%) (100 kg/h)
= +/- 1 kg/h
