Engineering ToolBox > Fluids and Latent Heat of Evaporation
The input of energy required by a change of state from liquid to vapor at constant temperature, is called the latent heat of vaporization. When a liquid undergoes a change to vapor state at normal boiling point, the temperature of the liquid will not rise beyond the temperature of the boiling point.
The specific latent heat of vaporization is the amount of heat required to convert unit mass of a liquid into the vapor without a change in temperature.
| Product | Latent Heat of Evaporation | |
| (kJ/kg) | (Btu/lb) | |
| Acetic acid | 402 | 173 |
| Acetone | 518 | 223 |
| Alcohol | 896 | 385 |
| Alcohol, ethyl (ethanol) | 846 | 364 |
| Alcohol, methyl (methanol) | 1100 | 473 |
| Alcohol, propyl | 779 | 335 |
| Ammonia | 1369 | 589 |
| Aniline | 450 | 193 |
| Benzene | 390 | 168 |
| Bromine | 193 | 83 |
| Carbon dioxide | 574 | 247 |
| Carbon disulfide | 351 | 151 |
| Carbon tetrachloride | 194 | 83 |
| Chloroform | 247 | 106 |
| Decane | 263 | 113 |
| Dodecane | 256 | 110 |
| Ether | 377 | 162 |
| Ethylene glycol | 800 | 344 |
| Freon refrigerant R-11 | 180 | 77 |
| Freon refrigerant R-11 | 165 | 71 |
| Freon refrigerant R-11 | 232 | 100 |
| Glycerine | 974 | 419 |
| Helium | 21 | 9 |
| Heptane | 318 | 137 |
| Hexane | 365 | 157 |
| Hydrogen | 461 | 198 |
| Iodine | 164 | 71 |
| Kerosene | 251 | 108 |
| Mercury | 295 | 127 |
| Nitrogen | 199 | 86 |
| Octane | 298 | 128 |
| Oxygen | 214 | 92 |
| Propane | 428 | 184 |
| Propylene | 342 | 147 |
| Propylene glycol | 914 | 393 |
| Sulphur | 1510 | 650 |
| Toluene | 351 | 151 |
| Turpentine | 293 | 126 |
| Water | 2257 | 970.4 |
Latent heat of evaporation at atmospheric pressure.
