Engineering ToolBox > Flywheel Kinetic Energy
Kinetic energy and moment of inertia of a flywheel
A flywheel is used to smooth the energy fluctuations in combustion engines and make the energy flow uniform. The flywheels store energy mechanically as kinetic energy.
Kinetic Energy
The kinetic energy of a flywheel can be expressed as
Ef = 1/2 I ω2 (1)
Ef = flywheel kinetic energy (Nm (Joule), ft lb)
I = moment of inertia (kg m2, lb ft2)
ω = angular velocity (rad/s)
Angular velocity converting units
Moment of Inertia
Moment of inertia quantifies the rotational inertia of a rigid body and can be expressed as
I = k m r2 (2)
k = inertial constant - depends on the shape of the flywheel
m = mass of flywheel (kg, lb)
r = radius (m, ft)
Inertial constants of some common types of flywheels
Moment of Inertia Converting Units
Flywheel Rotor Materials
Material Density
(kg/m3)
Design Stress
(MN/m2)
Specific Energy
(kWh/kg)
Aluminum alloy 2700
Birch plywood 700 30
Composite carbon fibre/40% epoxy 1550 750 0.052
E-glass fibre/40% epoxy 1900 250 0.014
Kevlar fibre/40% epoxy 1400 1000 0.076
Maraging steel 8000 900 0.024
Titanium Alloy 4500 650 0.031
"Super paper" 1100
S-glass fibre/epoxy 1900 350 0.020
