Engineering ToolBox > Pipe Bends and Thrust Block Forces
Pipe bends and thrust blocks forces on anchors due to fluid velocity and internal pressure - online resulting force calculator
pipe bend thrust forces
Online Pipe Bend Resulting Force Calculator
The calculator below can used to calculate resulting force in piping bends:
ρ - density of fluid (kg/m3)
d - internal diameter of bend (m)
v- velocity of fluid (m/s)
β - angle of bend (o)
p - gauge pressure (kPa)
The resulting force on a thrust block or anchor depends on the fluid mass flow and flow velocity and the pressure in the bend.
Resulting force due to Mass flow and Flow Velocity
The resulting force in x-direction due to mass flow and flow velocity can be expressed as:
Rx = m v (1 - cosβ) (1)
    = ρ A v2 (1 - cosβ) (1b)
    = ρ π (d / 2)2 v2 (1 - cosβ) (1c)
Rx = resulting force in x-direction (N)
m = mass flow (kg/s)
v = flow velocity (m/s)
β = bend angle
ρ = fluid density (kg/m3)
d = internal pipe diameter (m)
π = 3.14...
The resulting force in y-direction due to mass flow and flow velocity can be expressed as:
Ry = m v sinβ (2)
    = ρ A v2 sinβ (2b)
    = ρ π (d / 2)2 v2 sinβ  (2c)
Ry = resulting force in y direction (N)
The resulting force on the bend due to force in x- and y-direction can be expressed as:
R = (Rx2 + Ry2)1/2 (3)
R = resulting force on the bend (N)
Example - Resulting force on a bend due to mass flow and flow velocity
The resulting force on a 45o bend with
can be calculated by as
Resulting force in x-direction:
Rx = 1000 π (0.114 / 2)2 202 (1 - cos45)
    = 1196 (N)
Resulting force in y-direction:
Ry = 1000 π (0.114 / 2)2 202 sin45
    = 2887 (N)
Resulting force on the bend
R = ( 11962 + 28872)1/2
    = 3125 (N)
Note - if β is 90o the resulting forces in x- and y-directions are the same.
Resulting force due to Static Pressure
The pressure and the end surfaces of the bend creates resulting forces in x- and y-directions.
The resulting force in x-direction can be expressed as
Rpx = p A (1- cos β) (4)
    = p π (d / 2)2 (1- cos β) (4)
Rpx = resulting force due to pressure in x-direction (N)
p = gauge pressure inside pipe (Pa, N/m2)
The resulting force in y-direction can be expressed as
Rpy = p π (d / 2)2 sinβ (5)
Rpy = resulting force due to pressure in y-direction (N)
Rp = (Rpx2 + Rpy2)1/2 (6)
Rp = resulting force on the bend due to static pressure (N)
Example - Resulting force on a bend due to pressure
Rx = 100 π (0.114 / 2)2 (1 - cos45)
    = 299 (N)
Ry = 100 π (0.114 / 2)2 sin45
    = 722 (N)
    = 781 (N)
