Engineering ToolBox > Friction and Coefficients of Friction
Friction theory and coefficients of friction for some common materials and materials combinations
Frictional force can be expressed as
Ff = μ N (1)
Ff = frictional force (N, lb)
μ = static (μs) or kinetic (μk) frictional coefficient
N = normal force (N, lb)
frictional force
For an object pulled or pushed horizontally, the normal force - N - is simply the weight:
N = m g (2)
m = mass of the object (kg, slugs)
g = acceleration of gravity (9.81 m/s2, 32 ft/s2)
Frictional Coefficients for some Common Materials and Materials Combinations
Materials and Material Combinations Static Frictional Coefficient - μs
Clean and Dry Surfaces Lubricated and Greasy Surfaces
Aluminum Aluminum 1.05 - 1.35 0.3
Aluminum-bronze Steel 0.45
Aluminum Mild Steel 0.61
Brake material Cast iron 0.4
Brake material Cast iron (wet) 0.2
Brass Steel 0.35 0.19
Brass Cast Iron 0.31)
Brick Wood 0.6
Bronze Steel 0.16
Bronze Cast Iron 0.221)
Bronze - sintered Steel 0.13
Cadmium Cadmium 0.5 0.05
Cadmium Chromium 0.41 0.34
Cadmium Mild Steel 0.461)
Cast Iron Cast Iron 1.1, 0.151) 0.071)
Cast Iron Oak 0.491) 0.0751
Cast iron Mild Steel 0.4, 0.231) 0.21, 0.1331)
Carbon (hard) Carbon 0.16 0.12 - 0.14
Carbon Steel 0.14 0.11 - 0.14
Chromium Chromium 0.41 0.34
Copper-Lead alloy Steel 0.22
Copper Copper 1 0.08
Copper Cast Iron 1.05, 0.291)
Copper Mild Steel 0.53, 0.361) 0.181)
Diamond Diamond 0.1 0.05 - 0.1
Diamond Metal 0.1 - 0.15 0.1
Glass Glass 0.9 - 1.0, 0.41) 0.1 - 0.6,
0.09-0.121)
Glass Metal 0.5 - 0.7 0.2 - 0.3
Glass Nickel 0.78 0.56
Graphite Steel 0.1 0.1
Graphite Graphite (in vacuum) 0.5 - 0.8
Graphite Graphite 0.1 0.1
Iron Iron 1.0 0.15 - 0.20
Lead Cast Iron 0.431)
Leather Oak 0.61, 0521
Leather Metal 0.4 0.2
Leather Wood 0.3 - 0.4
Leather Clean Metal 0.6
Magnesium Magnesium 0.6 0.08
Nickel Nickel 0.7 - 1.1,
0.531)
0.28, 0.121)
Nickel Mild Steel 0.641) 0.1781)
Nylon Nylon 0.15 - 0.25
Oak Oak (parallel grain) 0.62, 0.481)
Oak Oak (cross grain) 0.54, 0.321 0.0721
Phosphor-bronze Steel 0.35
Platinum Platinum 1.2 0.25
Plexiglas Plexiglas 0.8 0.8
Plexiglas Steel 0.4-0.5 0.4 - 0.5
Polystyrene Polystyrene 0.5 0.5
Polystyrene Steel 0.3-0.35 0.3 - 0.35
Polythene Steel 0.2 0.2
Rubber Dry Asphalt 0.5 - 0.81)
Rubber Wet Asphalt 0.25 - 0.751)
Rubber Dry Concrete 0.6 - 0.851)
Rubber Wet Concrete 0.45 - 0.751)
Silver Silver 1.4 0.55
Sapphire Sapphire 0.2 0.2
Steel Steel 0.8 0.16
Teflon Teflon 0.04 0.04, 0.041)
Teflon Steel 0.04 0.04
Tungsten Carbide Steel 0.4-0.6 0.1 - 0.2
Tungsten Carbide Tungsten Carbide 0.2 - 0.25 0.12
Tungsten Carbide Copper 0.35
Tungsten Carbide Iron 0.8
Tin Cast Iron 0.321)
Wood Clean Wood 0.25 - 0.5
Wood Wet Wood 0.2
Wood Clean Metal 0.2 - 0.6
Wood Wet Metals 0.2
Wood Concrete 0.62
Wood Brick 0.6
Wet snow 0.14, 0.11)
Wood - waxed Dry snow 0.041)
Zinc Cast Iron 0.85, 0.211)
Zinc Zinc 0.6 0.04
1) Kinetic frictional coefficient
Kinetic versus Static Frictional Coefficients
Kinetic frictional coefficients are used with relative motion between objects. Static frictional coefficients are used for objects without relative motion. Static coefficients are somewhat higher than kinetic coefficients.
Example - Friction Force
The friction force of a 100 lb wooden crate pushed across a concrete floor with friction coefficient of 0.62 can be calculated as:
Ff = 0.62 100 (lb)
= 62 (lb)
