Engineering ToolBox > Froude Number
The Froude Number is a dimensionless parameter measuring of the ratio of the inertia force on a element of fluid to the weight of the fluid element - the inertial force divided by gravitational force.
The Froude Number can be expressed as
Fr = v / (g l)1/2 (1)
v = velocity
g = gravity
l = characteristic length
The Froude Number is relevant in fluid dynamic problems where the weight of the fluid is an important force. In general this is the situation for free surfaces as cold windows and hot radiators. It is used in momentum transfer in general and open channel flow and wave and surface behavior calculations in particular. The Froude Number is also important in analyzing flow in rivers and for water flow around ships.
