Engineering ToolBox > Fuels, Chemicals and their Ignition Temperatures
The ignition point for some common fuels and chemicals as butane, coke, hydrogen, petroleum and more
The auto-ignition temperature - the minimum temperature required to ignite a gas or vapor in air without a spark or flame being present - for some common fuels can be found below:
Fuel or Chemical Temperature
(oC) (oF)
Acetaldehyde 175 347
Acetone 465 869
Acetylene 305 581
Benzene 560 1040
Bituminous coal 300 572
Butane 420 788
Carbon 700 1292
Carbon  - bi sulfide   300
Carbon monoxide 609 1128
Charcoal   660
Coal-tar oil 580 1076
Coke 700 1292
Cyclohexane 245 473
Diethyl ether 160 320
Ethane 515 859
Ethylene 490 914
Ehtyl Alcohol 365 689
Fuel Oil No.1 210 410
Fuel Oil No.2 256 494
Fuel Oil No.4 262 505
Heavy hydrocarbons 750 1382
Hydrogen 500 932
Gasoline 280 536
Gun Cotton   430
Kerosine 210 410
Isobutane 462 864
Isobutene 465 869
Isooctane 447 837
Isopentane 420 788
Isopropyl Alcohol 399 750
Light gas 600 1112
Light hydrocarbons 650 1202
Methane (Natural Gas) 580 1076
Methyl Alcohol 385 725
Naphtha 550 1022
Neoheaxane 425 797
Neopentane 450 842
Nitro-glycerine   490
n-Butane 405 761
n-Heptane 215 419
n-Hexane 225 437
n-Octane 220 428
n-Pentane 260 500
n-Pentene 298 569
Oak Wood - dry   900
Peat 227 440
Petroleum 400 752
Pine Wood - dry   800
Phosphorous, amorphus   500
Phosphorous, transparent   120
Production gas 750 1382
Propane 480 842
Propylene 458 856
p-Xylene 530 986
Rifle Powder   550
Toluene 530 849
Semi anthracite coal 400 752
Styrene 490 914
Wood 300 572
Xylene 463 867
The flammable (explosive) range is the range of a gas or vapor concentration that will burn or explode if an ignition source is introduced. Limiting concentrations are commonly called the lower explosive or flammable limit (LEL/LFL) and the upper explosive or flammable limit (UEL/UFL).
Below the explosive or flammable limit the mixture is too lean to burn and above the upper explosive or flammable limit is too rich to burn. The Auto-Ignition Temperature is not the same as Flash Point - The Flash Point indicates how easy a chemical may burn.
