Engineering ToolBox > Hazen-Williams Equation - calculating Friction Head Loss in Water Pipes
The Darcy-Weisbach equation with the Moody diagram are considered to be the most accurate model for estimating frictional head loss in steady pipe flow. Since the approach requires a not so efficient trial and error solution, an alternative empirical head loss calculation that do not require the trial and error solutions, as the Hazen-Williams equation, may be preferred:
f = 0.2083 (100/c)1.852 q1.852 / dh4.8655 (1)
f = friction head loss in feet of water per 100 feet of pipe (fth20/100 ft pipe)
c = Hazen-Williams roughness constant
q = volume flow (gal/min)
dh = inside hydraulic diameter (inches)
Note that the Hazen-Williams formula is empirical and lacks physical basis. Be aware that the roughness constants are based on "normal" condition with approximately 1 m/s (3 ft/sec).
The calculator below can used to calculate the head loss:
The Hazen-Williams formula is not the only empirical formula available. Manning's formula is common for gravity driven flows in open channels.
The flow velocity may be calculated as:
v = 0.4087 q / dh2
v = flow velocity (ft/s)
The Hazen-Williams formula can be assumed to be relatively accurate for piping systems where the Reynolds Number is above 105 (turbulent flow).
Note! The Hazen-Williams formula gives accurate head loss due to friction for fluids with kinematic viscosity of approximately 1.1 cSt. More about fluids and kinematic viscosity.
The results for the formula is acceptable for cold water at 60 oF (15.6 oC) with kinematic viscosity 1.13 cSt. For hot water with a lower kinematic viscosity (0.55 cSt at 130 oF (54.4 oC)) the error will be significant.
Since the Hazen Williams method is only valid for water flowing at ordinary temperatures between 40 to 75 oF, the Darcy Weisbach method should be used for other liquids or gases.
