Engineering ToolBox > Heat Emission Radiators
The heat output from a radiator is determined by the ambient temperature, the temperature of the radiator surface and the surface area of the radiator.
The formulas below can be used to estimate heat emission from radiators where the temperature difference between the radiator surface and the ambient air is 50oC (inlet water temperature 80oC, outlet water temperature 60oC and ambient air 20oC).
he heat emission from column radiators can be roughly estimated with the equation
P = kc Ve (1)
P = heat emission (W)
kc = 15000 - 17000 - constant for column radiator
Ve = external radiator volume (m3)
The heat emission from panel radiators can be roughly estimated with the equation
P = 41 kp l (1 + 8 h) (2)
kp = constant for panel radiator
l = radiator length (m)
h = radiator height (m)
The panel radiator constants for different panel radiator configurations can be set to
